Set up new Jet Hybrid Saw Today
>Good Afternoon Friends,
My #3 son took half a day off and helped move the new Jet Hybrid into the basement shop. Then we set it up. I found the instructions were very clear, pix and text and sequence were about perfect. All parts and associated hardware were present in correct numbers and packaged nicely, without too much preservative to mess up clothes and shop. Factory adjustments were right on the money. Fit and finish are superb. The two cast iron wings are a foot wide. Each is affixed with four mounting holes which correspond to four tapped holes in both sides of the saw top. Alignment was perfect. Rails were very easy to install. All mounting holes lined up perfectly. The Pro Shop fence is a real winner. It glides like a feather over the rails, yet locks rock solid, there is no discernable deflection. I found the index very easy to read. The fence is repeatable. I put it on a new Shop Fox mobile base. Although the base is rated for 700 pounds, I have difficulty moving the 300 pound saw over the smooth tile floor. It needs bigger casters. I am unimpressed with the Shop Fox mobile base. We mounted a newly sharpened Woodworker II blade, turned on the saw, and experienced woodworking rapture. The 1 3/4 hp motor seems to have plenty of power. There is provision for an additional wood table extension, and mounting hardware is included for that option. I have decided to make my own extension table. It looks as though my replacement saw will be a good one.
George
Re: Set up new Jet Hybrid Saw Today
Re: Glad to hear that..
>I hope you don't miss the old one - after all it went to a good home.
David Yoho
>George, congratulations on the new saw. It sounds like you and your new helper are getting on well. I think you'll come to trust and enjoy your new saw as much or more than your old "friend" you recently watched leave.
I still remember when I sold my Griz contractor saw and replaced it with the Jet cabinet saw. That Griz was a good saw and we made many nice pieces together. However, it didn't take long to get to liking the new Jet saw and we've been making more nice stuff together since. Still, that old saw sure earned its keep and got me to the point where I could afford something better.
Enjoy your new saw!!
David
Bruce, a MN Galoot
>Congratulations, Colonel!
Tell, me (since I'm in the market for a hybrid myself) why did you choose the Jet over the Steel City or some other?
Thanks
Bruce
Congratulations X 2
Tom Pilsbury (Chicago)
>First, congratulations on the new saw. Looks like you're pleased with your purchase. New toys are so much fun, aren't they?
And second, congratulations on having such a fine (and strong) son who goes out of his way to help the old man with the heavy work. You raised 'im up good!
>Good Afternoon Bruce,
I liked the Steel City hybrid saw very much, having seen it set up at a local Woodcraft. I read and watched the reviews at Popular Woodworking magazine and web site. I couldn't find any Jet Pro Shop saw on display, so the video shown on the Pop Woodworking web site was the only basis for visual comparison. There is a price difference of $200 between the Jet and the Steel City, and I couldn't find $200 difference between the two, and the Jet seemed to have a better fence and more powerful motor, according to the reviews. Plus, I have other Jet tools which operate very well (14" band saw with riser block, and Dominic's old 1236 lathe. My old table saw was a Jet contractor saw which I used for nearly 10 years, and that operated flawlessly throughout that time. So, I was already familiar with and favorably impressed with Jetequipment. The Jet Hybrid was out of stock equipped as I wanted with left tilt and dual cast iron wings. Woodcraft was finally able to obtain one, and I was able to take advantage of a 10% off sale on Jet equipment. I would have waited longer for the Jet saw, as the contractor saw I had been using was fine. Steel City's chances were diminished from the get-go because Jet, in my experience, is a tough act to follow.
George
Virgil Johnson, Versailles KY
>Cool. Have fun.
Brint in Richmond, VA
>Colonel --
The very first "woodworking tool" I bought, about twelve years ago (before I knew anything about buying WW tools), was a $175 Skil brand tablesaw. I soon discovered that it was fine for rough chopping wood, but the fence is so poor no amount of adjusting seems to be able to guarantee accurate alignment, and I can't see spending $$ on an aftermarket fence for this piece of equipment. I've been wanting to replace it for the better part of ten years, and have long had my sights on the Grizzly 1023SL. I just had a new shop built (14' x 22') and am planning to upgrade as soon as my, um, employment situation improves. I'm ashamed to admit that when the Hybrids started coming out, I was a little reluctant to admit that my needs as a hobbyist might actually be met by something "less than" the cabinet saw I so long had hankered after. But my conscience tells me I should give this new class of tool a fair shake, so I thought I'd ask (in light of your post): What made you decide to go for a hybrid instead of a cabinet? Just cost? Shop footprint? Power needs? (I had a 220V outlet wired in for the saw-to-be).
Any wisdom you could share would be much appreciated. Thanks --
