Dust collection floor sweeps?
Scott in Montana
>Hello all,
I'm just finally finishing up my dust collection system and am wondering if installing a floor sweep inlet or two is worth doing? The system is based around an Oneida cyclone collector if that makes a difference. It seems to me that there might be a plethora of things that you wouldn't want to sweep into your dust collector. I'd sure value the input of those who have them, and whether or not they use them.
Thanks,
Scott
Re: Dust collection floor sweeps?
I LOVE mine ! . . .
steve mackay
>If I hadn't rigged it then I'd have done it later. Just an extra gate with a hose. Hook up the floor wand or other attatchments for the bench and peg board. Make sure you hang the crevice atatchment nearby for daddos, tight spots and such.
What About Risk of Metal Being Pulled In?
Howard
>Good Afternoon Scott,
I have one hooked up to a Bridgewood 1 1/2 hp DC. It is a very nice thing to have, and does save work when cleaning and sweeping the shop. Longer shards of wood decrease its effectiveness, in my opinion, because they "bridge" themselves across the opening of the sweep and impede smaller particles. Its easy enough to remove them from the pile of debris before sweeping it all under the scoop. Still, mine doesn't pick up all the scrap swept to it. Heavier and larger particles tend to remain. I regard my floor pick-up as well worth having. It saves time and labor. Work within any limitations and enjoy using it. Its a real convenience.
George
>I am presuming that you have some bends in the ductwork? Have your floor sweeps in a position where there are the fewest elbows, "Wyes" or reducers. Hopefully you have a clean-out nearby also. Just in case you get bridging when a long scrap goes in the sweep.
If you just have a long hose attached to your floor sweep, you probably don't have to worry about it. I just use the shop vacuum (not often enough according to the LOML).
Okay, mostly positive...
Scott in Montana
>I have ample suction and will have only one ninety degree and one forty-five degree elbow between the sweep and the collector.
Would installing a piece of stretched metal in front of the opening be a good idea? Maybe something with 3/8" to 1/2" openings work?
Again, I appreciate your input.
Scott
Re: Okay, mostly positive...
>Good Evening Scott,
I wouldn't put anything in front of the opening which would impede air flow.
George
Chuck in ND
>For me a floor sweep I think would be a bad idea because my shop doubles as a garage that I park my vehicles in and it is a dirt alley access. Sucking dirt into the DC just doesn't seem like a good idea to me, plus I would be concerned about anything metal geting sucked into it and starting a fire from a spark. Like what happened tonight, I was working on the table saw and I droped a 3/8" lock washer, I couldn't find the thing after looking for it for 15 minutes, so I gave up and put a new one on it. Someday it will show up, but my luck if I had a floor sweep thats where it would end up.
Benefits beat out risks
Mark McC
>I dont think the risks of a screw or something getting into the sweep and starting a fire or damaging the DC are that great.
Sure its possible,all kinds of things can happen with WW'g! Every now again a larger chunk of wood makes its way through and causes a Bang but its not like you can't see 99% of what you are sweeping into the system.
Just be mindful of what you are sweeping and avoid large chunks,screws,nuts etc. and it will be fine IMO.
Mine works great
Thanks to all for your valued input!
Scott in Montana
Joseph Mulherin, Sr.
>Scott, I would have a couple of the floor sweeps around if your shop is large enough for them, but when making one up I would suggest this:
do not put anything in front that will impede the flow of the shavings on the floor. And install a magnet inside the pipe to catch any metals that might be involved...you can check every so often to see if there are any metals there. Also, install a waste-gate on the opening if you have a floor sweeping like using your broom to sweep things into the opening.
I prefer to vac
JRutter
>I don't like brooms - they stir up too much dust into the air. In my commercial shop, I put in 3 4" drops and have a 20' long 4" flex hose that I hook up to vacuum the floors. With some creative fuittings, I adapted a shop vac floor sweep to use with it. Very clean!
Re: I prefer to vac
Bart Leetch
>I just use a shop vac it is small enough to poke into & around items & tools so I can get almost all the dirt & chips.All I have is a 2 HP DC with pleated filter & it fills up fast enough without filling it with anything else & the shop vac is easier to empty.
