>I'm setting up to saw a bunch of walnut next weekend, and would like recommendations for sticker wood. Stock will be sawn to 5/4 and 9/4, end sealed and air dried.
I've used 3/4 ply strips in the past, but had issues with sticker staining. Since this walnut has a significant amount of antractnose (causes heavy sap wood), I want to minimize any staining.
With 8 or 9 trunks to cut, I should come out between 5 and 700 bf. in 9 foot lengths ranging from 6 to 18" wide.
Also, comments on light spray of clorox water on the board faces to kill mold spores before stacking?
>Check the Wood Web knowledgebase for lots of good info. I've put a link below with the search criteria already applied.
Best to use dry heart wood. Green stickers invite mold. Most people use 1" rough cut. You can buy stickers ready made.
I cut stickers on my sawmill from junk 1" poplar, cedar, or whatever I have that won't make good lumber. For boards where I care about sticker stain or mold, I use dry stickers, but most of the time I don't care so I just stack with green stickers cut from the same tree I'm milling.
3/4" is probably the absolute minimum for air drying.
You may already know this, but here's my 2 cents on stacking anyway:
The foundation is the most important. Use concrete blocks to get the stack off the ground - some recommend at least 18" of space. Weeds and close ground will retain moisture in the lowest boards. I set the blocks about 3-4' apart and lay 3x3 or 4x4 beams down the length. These long beams will be as long as your lumber. Some people use three rows of blocks but I use two. Then lay shorter 3x3 or 4x4 beams crossways every 2' or so with supports very near each end of the stack to support the ends of the boards. The stickers will be aligned over top these cross beams. The foundation must be stable and straight (not necessarily absolutely level) or you will be forcing warp into the boards. Most publications recommend stacking boards tightly edge-to-edge with a gap or "chimney" near the center of the stack. This might be even more important with 3/4" stickers. Make sure each sticker is exactly aligned with the stickers on the previous rows. Cover the stack with old plywood or roofing tin - do not cover with a tarp or let anything cover the sides. Keep weeds cut back (herbicide is often used for this).
Google search for stacking lumber for air drying gave lots of hits. The first one I looked at had the little diagram below.
I've never tried spraying with bleach solution and can't remember reading anything about it. Some spray with borox solution to inhibit insect damage. You might try searching the WoodWeb knowledge base or ask that question there.
>a couple of years ago, I made a lot of stickers. I had harvested about five thousand feet of walnut and cherry form the family farm.
What I did was go to Lowes and buy their reject lumber. They put huge bundles of it outside in a bin and let it go cheap (about $800 worth for $100). I picked a pile that was mostly "white" wood. Some of it 3/4", but most of it was 2" stuff. I put a thin kerf blade on my TS and set it to saw right down the center of an 1 1/2" piece. Then, I ripped all the stuff so that I had pieces that were .7" X .7". I cut them all four feet long. These were as small as I dared, but made the most efficient use of my stock. Luckily most of what I started with was their Premium stuff and it had relatively few knots. A small knot will break a sticker this small.
John is right about the stacks. The bottom course must be "FLAT". If you start with a stack that is twisted, you could twist every piece of lumber. You can not keep every piece form warping, but you can ruin every piece.
I stacked mine with stickers about 16" apart and kept them lined up vertically. I left 1" spaces between the edges of the boards and about a two or three inch chimney up the middle. I weighted the top of the stacks with left over junk lumber from Lowes. I did not have to cover mine as they were in an open shed on the farm. Luckily, it was quite windy and the lumber dried nicely. No sticker stain.
I bought some home and stacked it in my green house which became an impromptu kiln. I put box fans on one side of the stack to blow air through. That worked also. Actually, walnut is pretty easy to dry, or maybe I am lucky.
It was important for me that the stickers either be Identical or OBVIOUSLY different. Don't make some of them .7" and some 3/4. you will get them mixed up and then you will have error creep into your stack. It mounts up. The planks might come out wavy.
>I found a place that will sell you all the oak stickers you want. The problem was that they wanted to sell a tractor trailer load at a time. I think they were 15 cents each, but I did not need that many.
>My drying rack is a 4x8 box made of PT 2x8's with 2x10 cross pieces set at 12"oc. The rack is leveled on 12 4" solids which sit on a vizqueen sheet to prevent grass etc. Also makes it easy to spray around and under for bugs. Made my stickers last night, and remixed the Anchorseal. Some of the logs have loose bark so I'll debark them with the power washer and we'll be good to go for next Saturday.
>Mark, here is a sort of "neener, neener, neener" aside. If you are putting down visqueen and you have not done it yet, use black and use two of three layers. Visqueen breaks down fairly quickly in sunlight (UV). The top layer will weaken and break down in a few weeks but should remain intact enough to shield the lower layers. Clear visqueen fails quickly and acts almost like a green house promoting weed growth under it.
