Coffee Table plan?
Coffee Table plan?
Coffee Table plan?
Warren E. White
>Good afternoon!
I have some nicely figured maple that I would like to use for a coffee table top, with the legs and apron from cherry.
I am looking for plans that would work with these woods. I would like the top to appear to 'float.'
I haven't been successful in finding any plans and wonder if anyone could offer any suggestions or pictures of their project.
Thank you,
Warren
Re: Coffee Table plan?
I'm no expert, Warren,
henthorn
>but when I did it I just used a couple of risers that were through tenoned into the aprons. I shaped the risers so that inside the aprons they were apron to apron but above the aprons they were curved back so they weren't obvious. I also cut the bottom of the riser so that it matched the upper part making it easy to drive screws through the riser to hold the top. I elongated the screw holes on one side so the top had room to expand. Hope this is understandable and is of use. If not e-mail me.
Design your own
>Warren, here's your chance to be a designer, instead of relying on someone else's plans. Ask yourself where the piece will live and what the surroundings are that it will have to blend with. You've already figured out the wood combination, so the color palette is known. What is the style that would work best in this situation? Once you decide on the general look, get specific about the dimensions -- how long, wide, and tall should the table be? Then, if you want a top that appears to float, try the method suggested above or look through some design books and magazines for other approaches that resonate with your vision.
Design isn't something that only other people do, it comes from within. It is a problem-solving process that is enjoyable and productive. I wish more people would trust their instincts. If you like, do some sketches and samples and such and post them here for comment.
Ellis Walentine, Host
