Cleaning router bits?
>On my non-bearing router bits, I've been soaking them in Simple Green and water and then having at them with an old tooth brush. The bits with bearings, I typically remove the bearing and then do the Simple Green soak.
Does anyone have any better/different ideas?
Re: Cleaning router bits?
Lee Schierer - McKean, PA
>There was a post about a year or so ago that listed simplegreen as being derimental to either the carbide, the brazing or both. It might have been the industrial strength version. There was an ealry post this month about cleaning saw blades that had lots of good information.
My take on it is that most of the products being used by woodworkers for bit and blade cleaning have some effect on the carbide or braze so clean them with what ever you want, but soak them for as little time as necessary to get them clean. Rinse well with water and apply a water repellant material like T-9 or WD-40. Bearings should never be soaked or sprayed with any material that might attack the lubricant.
Your mileage may vary....
Lee
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I usually tear off a little piece of steel wool, and wet it with lacquer thinner, and scrub it.
For saw-blades, I have an old drill that I keep a cup shaped wire brush in. Although I suppose any shape would work, but I run the wheel so the bristles come off of the plate, up the back of the tooth, away from the edge.
I just stick a screwdriver through the arbor hole, into a hole in the end of one of my work tables, to keep it from spinning off the table. It only takes about a minute to clean the outside of the teeth, without messing with any chemicals.
CMT Formula 2050
>Good Eveniong JL,
I bought a pump jar of the stuff about 6 years ago and squirt my bits and blades with it on newspaper. Its "industrial strength", biodegradable and non toxic. After 5 minutes or so I scrubb with a tooth brush, not necessarily the one I use every morning. After wiping the tool, I wash it with tap water and dry. Works fine. My teeth are much brighter, too.
George
Re: CMT Formula 2050
Paul Waddle
>Does it do a good job on the gold crowns too??? pw
Ralph Turney
>I use baking soda and warm water, soak for a little while and then clean off the gunk with a tooth brush. This method also works with saw blades. I always have baking soda around and don't have the smell associated with other cleaners.
Check BillTindall's article in Articles Section
Garrett in Victoria
