Extra thin mdf?
Extra thin mdf?
Extra thin mdf?
pecker
>I need a sheet material...something similar to mdf, but thin. Like 1/16", maybe an 1/8". 2ft x 4ft sheets would be more than big enough.
It should have a smooth paintable surface. It would be great if I could apply it with cold press veneer glue in a vac press, although I could also use contact cement if necessary. Sorta like formica, but without the shiny part.
This is gonna be applied over a flat surface that has adjacent sides containing angles and curves, so I won't be able to trim it to size with a flush bit in a router. I will have to cut it close to size, glue it, then hand sand it flush. So it shouldn't be too hard of a material.
Any ideas? It would help if it was readily available and not too pricey, also. When I looked at 1/8" tempered hardboard, the cut edges looked too fuzzy and layered...like they might separate or show through the paint.
Re: Extra thin mdf?
Re: Extra thin mdf?
Jim Shaver Oakville, Ont.
>I bought some 1/8 mdf last week at HD. Hardboard might work for you also.
Thanks,
Jim
Re: Extra thin mdf?
Untempered hardboard
>I don't know if oil-tempered hardboard (Masonite) will give you a reliable enough bonding surface, so maybe you can find untempered board somewhere. Any fiberboard product you use, though, will have issues with fizzy edges and paint absorption. We've had a lot of threads about preparing MDF edges for paint. My favorite is still to smear yellow glue (hide glue would also work) on the edges and sand them lightly before painting.
Another option you might consider is door skin. This is very thin plywood like you find on typical hollow or solid core doors. Plywood wholesalers sell it.
Ellis Walentine, Host
Re: Extra thin mdf?
You could try this...
Kris Lasure
>Go to your local cabinet shop that works with laminate and ask if they have a scrap piece of laminate backer. Laminate backer is thin pieces of built up kraft paper that is used under countertops to help balance the deck. Same as you would do with a veneered panel. I use it on countertops when there is minimal support for the top (knee brackets only and such). You can use PVA glue or for a quicker bond use contact cement. It has a very smooth face and you can sand the egde very easily and it cuts with heavy duty scissors easily as well. I never have put paint on it, but I don't see any issues with doing so.
I always have scraps that I would rather give away than throw in the trash.
Re: Extra thin mdf?
It used to be called "masonite"
Forrest Addy
Re: Extra thin mdf?
Re: Extra thin mdf?
Keith Newton, LR, Arkansas------WebKitFormBoundary
>If you are in a city large enough to have a plastic laminate distributor, who supplies all of the lumber yards and cabinet shops, check with them for their cover sheets that come on the pallets of laminate.
Sometimes they have been sanded on both sides, and will make a good paint face for bent laminates, or even backer for veneers etc.
The warehouse guys usually will save a few pieces if you tell them that you use them for patterns. Free.
