Best wood for feather board
Wayne Carson
>looking to build some feather boards for table saw. What is the best wood for this purpose.
Wayne Carson
Scrap
Neal in San Jose
>I've made featherboards out of oak, cherry and maple. Those are the ones I can find right now, there may have been others. Any straight grained hardwood will work fine.
I like pine......
Jesper, Denmark
>Make sure the feathers are not too short.
I also like to have the feathers raised a little above the table so that they move freely, so I glue a thin piece of wood under the clamping area of the featherboard.
Not sure it matters
>Looking back, I have most often used pine or poplar for featherboards, but there's no reason not to use hardwood. Each wood has a different stiffness, but you can adjust the amount of spring by varying the spacing and thickness and length of the feathers.
Re: Not sure it matters
Ken Oakley-Sunny St. Cloud, Fla
>I have used with success Plexiglas,(at least 1/4" thick), as well as baltic birch plywood in many instances. Mainly because they were the material most available at the time.
Bingo
Robin Corell in Atascadero, CA
>The pair I have in use currently are made out of elm because that is what I had laying aroung. the previious pair were MDF and in use they worked exactly the same because I made the width of the feathers 1/8" thick on the elm and 1/4" on the MDF.
Robin
Knot free scrap
Lee Schierer - McKean, PA
>Any piece of knot free scrap will work. Knots tend to break when it is most inconvenient so I recommend knot free material.
Lee
Even scrap plywood (3/4") works fine
North of the Border
