Joel's article on grinding
John Pappas
>The current issue of FWW has a very informative article on grinding by Joel Moskowitz. While I can say that I generally avoid burning a tool while grinding, there are times when I fail. I'm eager to put his tips to use...especially the slight crowning of the grinding wheel. Anyone have comments for or against dressing a wheel with a slight crown?
Re: Joel's article on grinding
Not from me.
Forrest Addy
>Dress a sight crown if it helps you get the results you want but dress it whenever the wheel gets dull and tries to overheat the work. It's rubbing friction that transmits the heat of grinding to the edge you're attempting to grind. If the wheel is sharp, properly dressed, and a true cylinder (or face) then grinding proceeds rapidly with only a moderate tendancy to heat the work.
While I have't read the article I fervently hope that wheel dressing was emphasized. A grinding wheel is a cutting tool with thousands of cutting edges (abrasive grains) that get dull with use. A grinding wheel is sharpened (dressed) by knocking out the dull grains from the frangible bond and at the same time trueing its periphery either as a true culinder or with a slight crown if that's your wish. I prefer a straight cylindrical dress myself.
Re: Not from me.
John Pappas
>Yes,he does stress dressing the wheel....big time.
I crown
Bill Tindall, E.TN
>While I started with 1" wheels thinking a larger surface to register against would be useful, it is not. I think the best and cheapest wheel are 1/2" wheels for a surface grinder, available in a multitude of grits, bonds and compositions for less than $20.
more on dressing
Bill Tindall, E.TN
>For tool shaping tasks it is necessary for the wheel to hold its shape, hence a harder bond is required. But for grinding plane irons and chisels one can effectively use a very soft bond, like H. A soft bond wheel is largely self dressing. Other than for reshaping I rarely have to dress an H bond wheel for it sheds used grits about as fast as they get full. A soft bond coupled with a friable particle continuously exposes new abrasive edges much like a water stone. So long as light griding pressure is used edge burning is not an issue. I typically grind right to the edge of tools as the first step in sharpening even with a 3600 rpm grinder.
