Re: Latest FWW Article
Steve Schoene
>There are a lot of aspects of that finish in FWW that give me questions I can't answer.
First, how can adding raw Tung Oil increase the water resistance. Sure tung oil as an ingredient in varnishes aids in producing a varnish with good water resistance, but this is just making an oil/varnish mix.
I suppose the Klean Strip Japan Dry does have some impact on Tung Oil, but I don't think all do. And, the amount used is over twice that given by Klean-Strip as the maximum to use. I suppose with so much drier, the Tung Oil is necessary to keep the varnish from getting so brittle that is crazes, but is this a true balance, or a relatively short term effect that could bite 10 years down the road.
Frankly the act of thinning the varnish and applying such thin wiped on coats gets it "out of the dust" just about fast enough. If it's slow enough drying to apply by hand, it's going to pick up enough dust that some rubbing is going to be necessary for just about every thing except shop jigs--and I don't often put finish on them.
I'd like more assurance that the chemistry really works out OK and some longer term or systematic testing.
