Waterproofing over cement board in a shower?
Steve Silca
>I've read some websites that insist on, in a addition to taping and mudding the seams of a cement board shower enclosure, applying a couple coats of a waterproofing product to the cement board. I don't see this product at the first Home Depot I went to. Does anyone know what this product would be called or of its availability?
Thanks in advance.
Re: Waterproofing over cement board in a shower?
Absulutely unnecessary
Second the motion...
doug f, san clemente, ca
>After you've mudded and taped the corners and seams and applied a coat of thinset for tile, you're as waterproof as you're going to get. Waterproofing would be expensive and unnecessary.
Doug
It may also prevent tile from bonding well to base
Dave Bair, Eaton Rapids, MI
>I ended up putting a layer of polyethylene UNDER the cement board (between the studs and the cement board) when I did this. I just put the thinset on top of the cement board.
NickB
>Are we talking the walls of a shower enclosure? If so, then you shouldn't need to apply a trowel-on membrane (this is the product you heard about, several companies make them, and it should come as no surprise that you can't find them at a big box), so long as your pan or receiver (the shower floor) is properly installed/detailed *and* you make sure that the walls cannot wick moisture from the pan/receiver (maintain a separation from the CBUs and the pan/receiver and it is a good idea to seal the bottom edge with a silicon sealer). CBUs are not waterproof, and they will wick moisture like most any other concrete-containing product.
If you're doing tile work yourself, do yourself a favor and order a copy of the TCA Handbook (it's all of $5 or $6) from the Tile Council of North America-it will outline proper waterproofing structures (and proper materials and details for a variety of tiling scenarios). You used to be able to lurk on the tile setting bulletin board at JLCOnline (not sure if that is free anymore), and learn a lot there.
Hope this helps,
Nick
Justin Szeliga
>There are a couple products that can be troweled onto cement backer board, the one available at the big box store tends to be RedGuard. They add a level of protection most people don't need & are expensive. It can be necessary, but most of the times a trowel on membrane is more than is needed. The cement board will not breakdown the way green board will, greenboard falls apart as soon as water gets to the core, which it does through the edges, screw & nail holes & should not be expected to last more than 5-10 years in a shower or tub. The best way to build a dry, long lasting shower in my opinion is to use a product called Kerdi, from a company called Schluter. Comes as a 40" wide sheet, goes up over regular drywall, & the tile is set onto it after the thinset mortar sets up. Great stuff, reasonably priced, easy to work with. MUCH easier than wet bed work.
The best place for tile advice on the web is at TileYourWorld.com. The Woodcentral of tile.
Peace
Justin
