Rail and Stile Question
Bill H
>I recently bought a rail and stile bit set and made the first parts today. I've read that some people make their parts oversized (e.g. the stiles are 1/8" wider and 1" longer than needed). Do you glue the doors up this oversized and then trim them down on the table saw? This seems like a nice safety net, but if the door is square to start with, then it is just another chance for me to screw something up. Any opinions?
Thanks in advance,
Bill
Re: Rail and Stile Question
Carol - now in NC Nebraska
>Depends on the door style. If they are insert, I do them oversize. If they are overlay, I make them the final size. You could make these slightly oversize as well if you are concerned about dead on square glue-ups.
David Yoho
>Probably what you read about making the parts over-sized has more to do with being able to go back after cutting the profiles at the router table and trim off any tear out that may have occurred.
David
John Foster
>In my limited experience, making a door is easy, Planning the size of a door is difficult. The four way intersection of gaps where two drawers are above two doors look like crap if they are out of line. Making your door 1/16 to 1/8 inch oversize gives you a bit of trim allowance to dress up you fit before finishing.
