OT - Firefox Opening Ads?
Garrett in Victoria
>Since the latest Firefox upgrade, instead of going directly to my Home Page (WoodCentral)ON STARTUP, Firefox displays advertisements. I've done Spyware and Virus scans and am clean, so am wondering if this is a new "feature".
Cheers, Garrett
Re: OT - Firefox Opening Ads?
Dave's Not Here
>Mine doesn't do that. Try this, click on Tools on the header toolbar, then click on Options on the drop down menu. Next click on the Main prompt then enter in the address you want your Homepage to be.
John McGaw
>It displays advertisements for what? What are the URLs involved?
Andrew F in Australia
>No problems for me, Garrett.
Maybe reset your homepage - it could be something to do with one of your addons.
Cheers,
Andrew
Some updates reset the home page
Ed Beck
>Sometimes when you update your browser software the default home page is reset. If you manually reset your home page you should be ok.
Re: OT - Firefox Opening Ads? - UPDATE
Garrett in Victoria
>Thanks for the replies. At least I now know the problem lies within my computer. Firefox Options hasn't changed, i.e. my home page remains WC.
I did another set of virus and spyware scans (AVG) overnight and found the same two viruses - "Lop" - that I had removed a coupe of days ago. They were in the Temporary Internet Files folder. Did a little more research and learned that these - and others - can 'hide' in the System Restore file and will reinstate themselves after being removed.
The recommended fix - after purging the Temporary Internet Files folder - is to right click 'My Computer', select properties, system restore, and click 'Turn off System Restore on all drives". That deletes all system restore files on the computer. Do another scan, take whatever action is required, then turn System Restore back on.
Did all that, thought I was clean, but now have a similar problem with a difference, i.e. WC comes up as it should but then the screen is replaced with a pop-up of some kind from http://www.buycheapadvertising.com/.
I'll continue to work away at this, including installing a pop-up blocker, and let you know if/when I get it sorted.
Cheers, Garrett
Bri in Mtl
>You might want to add the Firefox add-on Adblock Plus -works great.
