>I've installed the free edition of AVG antivirus and find that it takes about 6 hours to scan my system each day. That seems awfully long. Is that what I should expect? I understand it has a good reputation but are there better free options out there? Thanks.
>That is too long. I have been using AVG Free for several years. On my desktop it takes in the order on an hour in the background to scan every day. Do you have lots of very large files on the computer? I am using about 30 gb on my computer. The other question of course how fast is your computer? I am running XP Pro on a 2.4 gig dual core box.
>Thanks for the responses and for confirming my suspicion that the scans are way to slow. I am using about 38 gb and am running XP home. My processor is a pentium 4, 2.0 ghz with 512 mb of ram.
>Somethings wrong there. Even on my "cheapie" home machine, it doesn't take but about an hour and a half. (Don't remember the processor off the top of my head, but it's s-l-o-w with everything else.)
>This is where the difference between the Pro (paid) version of AVG and the free version exists. I'm able to configure a custom scan that it can run that will save time by not checking things it doesn't need to.
Still, I run the free version on my laptop and it doesn't take that long. One recommendation I would make to you would be to add some more memory. 512 is really a little south of what is known as XP's sweet spot, which is 1 gigabyte. Memory prices being as low as they are, take a look at adding an additional 1 gig to your existing memory. If you're not sure of what kind you need, you can go to Crucial Memory's Website (crucial.com) and have their automatic scanner check your system. It will report the specific details of your memory and its current configuration, as well as how much more your system can hold. They also provide specific choices for modules that will fit your computer. I usually find out what I need there and then go over to NewEgg and order the OEM equivalent of either Crucial or Corsair brands.
I think a clean hard drive (defragged and at least 5 - 10 gigs of free space) and the additional memory will most likely make a difference in the time it takes for everything to run on your system.
>Thanks a lot for the suggestion. I run Diskeeper so I think I'm defragged and I've got about 40 gigs free on my hard drive. I'll give the additional memory a try.
