Band saw movement
JimG
>I recently bought an Iturra spring for my Powermatic 14" CS bandsaw w/riser. Now, when I lift the tension lever to set the tension, there is visible movement in the upper body, most noticeable at the upper bearing guides. Hard to say how much, 1/8" - 1/4". This is with a 1/2 in blade and the tension set to 1/2 (which I measured using a vernier caliper and seems to be about 15000), which I believe is about right. The saw works fine that way. But, I also bought a 3/4 in WoodSlicer. Now I am wondering if I should even try it, or if so not to tension to 3/4.
I'd appreciate any thoughts or sugesstions.
Thanks
jim
