>I really should know this but it's been a long time since I worked with electricity. Here's a crude diagram of how I plan to wire a router table. Switch A will be in front of the table and Switch B will be on the other side. Both are Double Pole Normally Open. Is it necessary to break both tabs on the outlet?
>What exactly are you trying to do here? Are you trying to have two routers, each with it's own switch? That's kinda looks like what you're going for, or at least what you'll get with this wiring. You made two seperate circuits, each with it's own switch and it's own outlet.
Or are you trying to have two switches that control one router?
Like mine for instance, where I must turn one both switches to start the router, but it can be shut off by hitting either switch off.
Or are you trying to make something that allows you to turn on yuor router with either one or the other switch, like a 3-way light-switch in a house. I think that would be a disaster since you up/down and on/off would get reversed from time to time.
>If you are trying to make it so that you can turn on the router with either switch, then you want to leave both tabs intac on that duplex outlet. By breaking both tabs, as shown in your diagram, you are creating two seperate circuits, whcih would be fine if your router table was going to have two routers in it (which would be cool).
>I can't imagine needing more than one switch on a router table unless he's building the worlds biggest router table. It looks to me like he's trying to put two switches on one router. I'd be interested in hearing the logic behind that. They have switches with a big paddle on them, you could pretty much turn that off from anywhere.
>I want to be able to operate the router from either side of the table. The plate is offset about 9" from the front leaving me about 15" or so to work from the back side for wider boards.
I'm thinking the way I have it drawn on paper will give me 2 seperate circuits. Plug the router in the top outlet and operate the router using the switch A from one side of the table and plug the router in the bottom outlet and operate the router using switch B from the other side.
Am I making things unduly complicated for myself?
The switches are both the large paddle type (Grizzly #HB241)
>If you want to control the router from two locations, just plug it in and control the outlet with two three way switches, just like you'd control a light from two locations with three way switches (which are effectively single-pole, double-throw switches). Much easier than having to remember which outlet half to plug the router into.
>I have a setup on my CMS where I can flip ONE switch and it turns on/off two seperate 15A circuits from my saw and ShopVac. Turning them on at the same time when I have them on the same circuit often tripped the circuit breaker.
>Unless I'm mistaken or there's something wrong with my house, single switch circuits are UP=ON and DOWN=OFF but the 3-way switches that control lights, the UP/DOwn is meaningless. One day UP=ON and the next day UP=OFF. While this is okay with light switches, it would be horrible for a powertool if you wanted to hit the switch off quickly.
>First of all you do not switch the white wire in any 120v circuit. A three way switch is a single pole double throw switch. Two three way switches will work fine ,if you think its needed. If the circuit is energized moving either switch will open the circuit,and either one will energize the circuit.
>Yes, it is a double pole switch. Couldn't tell from the catalog pic. (btw - it's Grizzly H8241 not HB. My typo) I bought this type for the large paddle style OFF feature. My main concern is safety, not convenience. I don't mind changing the plug from one outlet to another. Only takes a second.
Two single pole switches in series would have been much easier but I already have these so I'll just go with the original plan.
Your wiring diagram is overkill. Based on what you describe you want to do (and are willing to swap the plug between two sockets), then what you need are two SPST light switches and a duplex receptacle with the connecting tab broken on the hot (black/brass) side. Wire the common (white/silver) side of the receptacle to the common wire (white) of the incoming power line and wire each light switch in series between the hot wire (black) and one half of the receptacle. This will give you two independently switched outlets. There is no need to switch the common wire off or break the tab on the common side. Don't forget to run the ground wire (green) to everything.
If you want to use the DPST switches shown in your diagram because you have them on hand, just use one pole of each switch and ignore the other. Be very sure the switches you have on hand are rated to meet or exceed both the voltage and current requirements of the router.
However, if I moved around a lot I would hate to swap the power plug each time. Eventually something would wear out, perhaps my patience when I forgot to move the plug once too often. Another option would be a relay. You can control the relay from any number of low voltage switches put anywhere, wired in parallel. This is the type of system sometimes used in woodworking to turn on a dust collector remotely by opening any blast gate. (example in the link) You can buy such relays from many sources. One like that shown in the example looks attractive since it is nicely contained in a box - "plug and play". Depending on the robustness of your activation switches and wiring, for safety sake I would consider wiring a separate protected switch to remove the 110v power to the relay when changing bits. Without this, a jumping dog on the other side of the table or stray meteorite or cosmic ray could switch on the router at the wrong time. Turning on a router at the wrong time may have consequences different than turning on a dust collector.
