THE WOODRAT IS BACK!
New Garage Shop
New Garage Shop
New Garage Shop
Howard
>Will hopefully be breaking ground soon-25' x 25' 2x6 with r19 insulation and r30 in the ceiling. I know this has been asked before, I was considering using an overdoor commercial type electric or NG unit to heat the shop. Electric has the appeal of no pilot light while spraying lacquer inthe spray booth. Would appreciate all your recommendations and if you could tell me what you paid and how installation went it will be greatly appreciated. Thanks
Re: New Garage Shop
Louie Lovas
Re: New Garage Shop *LINK*
Louie Lovas
>I have a 30x30 shop and decided to go with radiant heat when I built it. Hot water pipes embedded in the concrete slab. Two reasons: 1) from what I was told it would be the most economical over the long run. 2) No blowing hot air stirring up dust.
I have a back room in the shop where the boiler is located, a very small unit run by propane. The whole thing was about $3,500 (4 years ago).
I'm not sure I'm saving much on propane, but the heat has been really great. The concrete slab is heated to about 70 degrees and keeps the room at 66 degrees, quite comfortable in a shop environment.
I have a spray booth in the shop that I've setup using an industrial curtain (http://www.goffscurtainwalls.com). Since I have no blowing hot air, no worries about stirring up dust to mess up a finish.
I don't have any pics of the boiler, but you can see the interior my shop at the link below (click on 'The Shop' button).
http://www.flinthillfurniture.com
Re: New Garage Shop
Re: Louis' shop
Ray Carson - Lawrenceville, NJ
>Wow...seeing your ShopSmith back there brings back some memories. I can remember being a kid (teenager) in my parents 10 x 20 shed (7 feet ceiling) building many projects. All the time cussing out the Shop Smith because I had to switch between the different attachments.
Yours looks to be in good condition. What model year?
Actually, I owned two Shop Smiths. I had (used) my Grandfathers for the longest time until my Dad sold it during my Pop-pops estate sell. Then my brother bought one and I took over the payments and spent a few years making sawdust until I sold it using eBay to some Naval guy down in North Carolina. Rented a Hertz truck and met the guy halfway in Frederickburg Va. at the Cracker Barrel. We unloaded everything to his pickup, had a bite to eat, and went our separate ways. We split the rental truck fees and I paid for gas. $1.50 back then. (ha ha ha)
Nice shop by the way...very clean and neat. Wish I could keep mine like that. :-)
Ray
Re: New Garage Shop
Re: New Garage Shop
Ray Newman
>Is the R-insulation values that you stated the minimum or the maximum for your construction?
Up here in WA ST, R-19 was the min. for 2X6. I had a house & detached shop built in '01, the contractor installed the max. R-21 in the walls & R-43 in the ceiling.
As I recall, the cost difference for the better insulation material was not that great. I recommend the max. am�t of insulation possible as energy costs aren�t going to get any cheaper.
Don't skimp on windows for the shop -- the contractor installed Low E, double pane windows in my shop as well as an insulated roll up door & access door.
For heat, a Modine "Hot Dawg" propane fired heater was put in. It has no pilot & vents to the outside. Electric is far too expensive & inefficient. I keep the thermostat @ 46-49 degrees & set it higher when I�m out there. It only takes a few minutes & the shop area (30X24�) of the 30X36� is warm.
Spraying -- several years ago, I saw The Light & converted to HVLP & water based & haven�t looked back....
Re: New Garage Shop
Re: New Garage Shop
Larry Clinton At Frankfort (Central)., Indiana
>Howard, I built my 30' X 30' 1 1/2 story shop about 4~5 years ago. I also built with 2X6 on 16 construction and "super" insulated the shop. I decided to use a conventional Home style High efficiency NG direct vent forced air furnace. I installed the furnace upstairs - with the return air in the shop ceiling and the hot air around the perimeter. There are a few advantages in doing this - 1) I added Central Air to the system when installing. If you don't want/need to do this at installation the unit can be installed so it is very easy to add at a later date. 2) Natural Gas is (at least today) much cheaper to operate than Electric. By using a direct vent style furnace the heat exchanger is sealed - It is as safe as electric heat as far as igniting vapors. The perimeter heat is very even, I don't think there is more than 5 deg. variation in the shop temperature, even on a subzero windy day. There are advantages to using CA in the shop, beyond the comfort issue. I have no problems with rust on my cast iron, and the (several thousand BF) of lumber stored is held at in a moisture controlled environment similar to what it will see in the houses where the finished furniture will be used. I keep the shop at about 65 ~ 75 in the winter and about 70-72 in the summer even when I am not using it. I estimate my heating cost in Central Indiana to be less than $50/mon. in the coldest months and less than $30 for air conditioning in the hottest months. The furnace I installed is also a multi-position unit. It can be installed as an updraft, downdraft or in a horizontal position.
Re: New Garage Shop
Louie Lovas
Re: Louis' shop
Louie Lovas
>Thanks for the comments, the shop's my getaway - plus I make a bit of money too!
I've had the Shopsmith about 12 years, I bought it used, came with a whole bunch of attachments - most of which I've long since sold on eBay. I actually built a crate for the bandsaw and shipped to Illinois. Nowadays I just use it for the belt sander, jointer and lathe. I have a shop full of dedicated machines for everything else.
When I was a kid may neighbor had one - so when this one came my way I knew what I was getting into what was a good price. This is a model 500 from about 1980. I've never bothered with any of the upgrades - way (way) too expensive and not relevant to my use of the machine.
I'm a bit of a neat freak in the shop, drives me nuts when I can't find something because it's buried under a stack of stuff.
Re: New Garage Shop
Re: New Garage Shop
>I have a full two story 30x40 shop/studio of 2x6 construction, fully conditioned winter and summer with a forced air electric heat pump. I maintain the temperature between 60 and 75 year round. The average electric bill for the last 47 months through February, including lighting and tools, has been $60.69 per month. It's a trouble free setup. I'm located in East Central PA.
Clint
Re: New Garage Shop
Hey Clint - What Brand Pump??
Howard
Re: New Garage Shop
Overhead radiant heat
Mitch from Canada
>Hi there,
I've been looking at adding a heater to my shop/garage. 18' x 31' with a 10' ceiling. A couple of people recommended a NG overhead radiant heater. I've read that they are 80% efficient and there is no open flame. Everything vents to the outside and draws from the outside. Going with in floor heat would be great, but not an option for me.
One quote I had was for a 45,000 btu overhead unit at about $1100.00 but they want to charge about $1600.00 and up to install it. I'm now looking to contact a friend of my wifes who has his ticket to install the units. I know he'll charge me alot less than $1600.00 for the install.
If you don't know anyone like that, post an ad on Kijiji or Craigs list in your area for someone qualified to do it. Alot of guys who work for the big companies also do side jobs at great deals. Just make sure they are qualified and get permits so that everything will pass inspection after.
Just a thought.
Mitch
