QSWO design question
wilbur
>I was thinking about making a stand for a TV and A/V equipment out of white oak. (Think low bookcase 48"W x 30"H x 20"D with a middle divider.) I thought about using quartersawn white oak, but then I realized that after everything was put into the case, the only visible elements would be the left and right panels.
So if you were making a bookcase-like piece out of QSWO, do you only use the QSWO on the sides, or do you use it for everything anyway?
Re: QSWO design question
I use Plywood
Dustmaker Mike
>I get 3/4" oak ply and use it every where the wood will not be seen. I would them use the real wood where it is seen. This saves money along with a lot of stress of the real wood moving around inside the cabinet.
Re: I use Plywood
wilbur
>I thought about plywood, but for this project I'd rather go with solid wood, especially given the quality of oak plywood available around here.
Dave Bair, Eaton Rapids, MI
>I'd probably use QS for it all. That way, all the elements will tend to move the same amount in the same direction. QS will tend to move less than PS, so mixing the two could be more problematic.
