bandsaw tension gauge
Eric Anderson
>I saw a video and article about the inexpensive tension gauge for the bandsaw from John White in Fine Woodworking. I thought it was a great idea, but since I have a number of dial and digital calipers, I thought I would use a 6 inch caliper set with the jaws 5 inches apart. I clamped the jaws to the blade just as he did his jig. I put some tension on the 1/2 inch Suffolk Timberwolf blade just as he did and set the dial to 0. I then started to crank tension on the blade.
I have no doubt that the standard spring is weak, but I don't see really ANY MOVEMENT AT ALL from the caliper. I can't believe the tension that I will need to get the recommended 15,000 psi. I will collapse the spring and THEN some. I can't bring myself to put the tension on the blade that would bring the 2.5 mils of displacement on the caliper to get the 15,000 psi. Without some more confidence that I am going the right way, I am afraid I will break the saw (and I will be WAY past collapse of the spring). Can anyone tell me what I am doing wrong? Has anyone done this and can tell me what did your standard Delta gauge read (with the standard Delta spring) when you put 15,000 (or whatever PSI you used)?
By the way, I know about all the different methods, such as the flutter test, etc. I am doing this to get a feeling what a standard tension is and then I will go my own way, but I would like to at least experience what 15,000 psi is.
Re: bandsaw tension gauge
Ray Binnicker
>Eric,
Maby I'm lucky, which, by the way, is not normal for me, but my Delta 14" w/riser is, in my opinion, the best saw I could ever hope to have and here is why:
I use Timberwolf blades almost exclusively and needed to change one yesterday. My blade of choice is the 1/2" (3tpi). I use Iturra guides. I put the new blade on, put a little tension on using only the stock tension guage and spun the wheel by hand to ensure the blade was tracking in the middle, adjusted the tension to 3/8, set the guide rollers and started cutting veneer. I did the flutter test several times a few years ago and I always wound up with the tension set at 3/8. Now I don't bother with the flutter test and I get consistent 1/32" veneer off a new blade. I'm not bragging on myself; I'm bragging on what may be a 1 in 1,000 saws that doesn't seem to take a lot of fuss to keep it true.
Suggestion: Ensure your saw is tuned as good as you can get it, put a good blade on, do the flutter test, if you're using the 1/2" blade, set the tension at about the 3/8 mark and try it.
I agree with you, 15,000 lbs seems like an awful lot. If you have a good saw, and I believe you do, a good tune up and a good blade will do you well.
Ray Binnicker
