Fence handle snapped off -- #&^@$!!!
A.J. Hamler
A.J. Hamler
>The handle of my Jet Supersaw fence snapped off. Anybody hear me scream some carefully selected harsh language when it happened? I know we've gotten reports from at least two surrounding counties on this side of the river, and one in Ohio.
The handle is a solid rubbery grip with a threaded rod that screws into a hole in the lever built into the fence. Naturally, that threaded rod didn't have the courtesy to snap at a point outside the hole -- where I could easily grip it with pliers and work out the broken piece -- but about 1/16" down inside the hole.
Since I've never really cared for the fence it would be a great excuse to get a new one, but that's just not in the budget right now. Any suggestions at all on how to get that broken piece out of the fence lever?
TIA
A.J.
Re: Fence handle snapped off -- #&^@$!!!
Lee Schierer - McKean, PA
>Chances are the threaded part that is still in the hole is not threaded all that tight. Take a fine pointed punch and carefully tap the threaded piece on the outer circumference in the direction to unscrew it.
You can also drill a small hole and use an easy out to turn out the threaded piece. The hard part will be drilling the hole in the center.
Or drill the hole with a left hand twist drill bit and when the bit bites or binds the screw will come right out.
Lee
>While I was thinking about it, I would put some penetrating oil on it an let it soak, so it would be ready when the attack comes.
I would try and Easy Out or even one of those screw removers that Sears sells. (Grabit?)
Al Stokka - Cambridge, Iowa
>A.J.,
Have a buddy or neighbor with an arc welder? Weld some metal thing to the broken rod, grab the thing with a pair of pliers or locking pliers and turn it out. Gas welding can be done but it would likely burn the paint of the external part.
Al
C'mon AJ, I'm sure you can remember..............
Art Silva
>plenty of people at Jet to scream on. We could probably assemble a chorus of screamers right here at WC. All you have to do is pick up the Choirmaster's baton.
Larry Clinton At Frankfort (Central)., Indiana
>A.J., I would put some penetrating oil on the bolt and let it sit overnight. Then I would use a left hand drill bit somewhat smaller than the bolt and drill in the center. If the bolt is big enough I would use at least a 1/4" bit. (Lets you use a fairly substantial easyout if needed later). Often the bit will grab and "unscrew" the remainder of the offending bolt. If the bit doesn't remove it, you can then use an "easyout".
Re: Use Left hand drill bit *LINK*
Bob Entwisle in NJ
>A quick google for left hand drill bits found this, I've not used this source for them but lefties are the way to go for drilling out a broken bolt etc.
http://www.mytoolstore.com/hanson/hanson.html
A.J. Hamler
Thanks, everyone!
A.J. Hamler
>Thanks, all.
Because I am the stupidest knucklehead on the face of the Earth (IATSKOTFOTE), a left-handed drill bit never occurred to me. That's the first thing I need. If it doesn't come out on its own, then an Easy-out or Grab-It. Unfortunately, living in Midddleofnowhere, W.Va., could make finding those locally a bit tough. We do have a great Mom & Pop hardware store over the river though that can surprise you with the things they have. That'll likely be my first stop for the drill bit.
Oddly, IIRC the folks at Sears may even have gifted me with one of their extractors when I attended an editor's conference several years ago. Since I never get rid of anything, I'm sure I must have it buried in my shop somewhere, but it'd likely take less time to walk to the Sears store 10 miles away and walk back than it would to find it in my shop.
Thanks again.
A.J.
Dale Lenz
Re: Thanks, everyone!
Dale Lenz
>Sorry for your trouble, AJ. Glad to hear you say, it's faster going to buy another "whatever" than looking for it in the shop somewhere. I've done that very same thing several times. Might not be $ wise, but sure is time wise. And I will do it again, I'm sure.
