Shop wiring...metallic cable
Joe Pack
>I need to run a 220 line for a couple of tools. The line will be hung high on a basement wall, out of the way, but still exposed, so I want to protect it. To give myself flexibility down the road, I plan on installing 5 outlets, but likely never using more than 2 at one time.
I don't want to mess with metal conduit, so I am considering using metallic cable. I can buy the metallic cable at HD for less money than buying the #12 single strands and running them in conduit. I have never used the metallic cable before, and I'm not sure of a small detail in connecting the cable to the metal box. The connectors are sold with plastic/nylon plugs. I'm sure these are to prevent scraping of insulation, but I am not sure where/how they are to be used. Do these insert into the metallic cable?
Re: Shop wiring...metallic cable
jerry mayfield
>The plastic parts are bushings and are used as you stated. What you are describing is referred to as metal clad (MC)we used to call BX armored cable.
Regards
Jerry
Randy Johnson Connersville IN
>As already stated, the plastic bushings are for protecting the wire from the edge of the flex.
Regular romex clamps (C-500)will work but there is a special connector made just for flex cable. I think they are called C-550s. The "C" connectors for romex and various cables are desingnated as if the fractions were in decimals. A 1/2 connector is a C-500, a 3/4 is a C-750, etc. up to C-2000 for large SE cable.
Don't let them sell you connectors for greenfield cable. They might work but will probably cost a lot more.
The most fun you will have is cutting BX without cutting the wire. It can be done by cutting diagonally across the rib with a hacksaw, but it's easier (once you get used to it anyway) to do it with diagonal cutters, aka dikes. If you have a lot of it to cut it might pay to buy one of the special cutters made for the purpose. I somehow managed to wind up with two, one by Greenlee and one by Lenox.
