O.T. Spicing 18g wire together
Alan Tolchinsky
>Hi All,
I'm mounting some undercabinet lighting that uses 18g 2 conductor wire. The wire is too short so I have to spice into it to make it longer. It has a special connector that connects into the lamp so I'd like to keep the original cord. I'd like to cut off the plug and splice 18g cord onto it. I always make all my electrical connections in a box but wondered if there's a simpler way to wire this light. Thanks.
__________________
Re: O.T. Spicing 18g wire together
Howard Norman
>First, is this a 110 volt or a twelve volt circuit? Since it is 18g wire that you are talking about I would assume a 110v circuit. If it is 110 I think that the splice should be in a box. However, you might look for a matching pair of connectors that could be fastened to the ends and then plugged together. I don't know what places like Radio Shack might have for that purpose.
Howard
UL-Approved splicing connectors
>Back in the days when I was making custom lighting, we used these little splicing connectors that consisted of a plastic housing with metal scissortails inside (sort of like in a telephone punch-down box) that cut through the insulation and made solid contact with the copper wires when you closed the top of the connector. Another kind simply has holes in both ends where you stick the conductors and then crimp down a metal splicing piece with pliers. Both worked quickly and well and both were UL approved, so no box is necessary. But, don't take my word for it. Ask for them (they come in all different wire gauge sizes) at your local electrical supply store and get the latest code from someone who is up on the lowdown.
Yes, this is 110v circuit
Alan Tolchinsky
>Thanks for the ideas. I guess I'm more comfortable making all connections inside a box even if it's overkill. Any other ideas are welcome though.
>Seems like several options.
a. Have you tried removing the special connectors so they can be reset on new cord? That would give you a home run to the wall with no splices.
b You can also consider a linesman's splice with heat shrink. Strip 1" of each wire and separate the two conductors for 2 " on both sides. Slip 2 4" pieces of heat shrink over both wires and past the splits. Put 1 2" piece of smaller heat shrink on each lead. Bring the like conductors together (ribb-to-rib, smooth-to-smooth). Twist one bare section around the other in one direction, then wrap the other around the first in the opposit direction so what you have looks like a Fisherman's knot. This splice is very strong and is used by, you guessed it, power company linesmen in the field. Slide the small heat shrink from one side over and heat, then do the same with the other. Repeat the process with the other conductor. When you've done both conductors so that they're spliced and "wrapped" with a double layer of shrunk insulation, slide the larger heat shrink over both and heat to shrink them until tight.
Takes longer to write this that it does to do the splice.
mm
[Not an electrician nor do I play one on TV]
Alan Tolchinsky
>Thanks Mark, That sounds like something that would be strong and safe. I'll check out the Borgs for the shrink tape. Thanks again to Mark and all who answered.
Re: Shrink Wrap *LINK*
>Alan,
It's not tape, but rather a tube of plastic. You can find it at Radio Shack, but the cheapest I've found is at Harbor Freight at the link.
Heat-Shrink Insulation
Re: Shrink Wrap
Ronald Walls
>No doubt about it. Shrink Wrap it.
