somewhat OT remote window operators
jared
>HEllo: We have been working for several months on what I guess will be our retirement/second home on the north shore of Lake Superior. My wife and I just got back from a week of intensive interior painting. Lest we get too anxious, it will still be several years before we are able to use it as much as we like. Several factors came together to make this the right time to build even though actual retirement is several years away. We have several clerestory windows in the living room and bedroom. They are Pella awnings. We got a long crank on a pole from Pella that was supposed to work but the windows are just too high and the 2x6 walls are too thick too allow the visibility needed to make it work. The alternative is a remote controlled electric operator. Prices quoted to me were in the $500 range for each window which I thought was way too high[7 windows]. Does anyone know of any other workable or cheaper ways to make these windows open? It would sure be nice for ventilation in the summer. Thanks in advance Jared
Re: somewhat OT remote window operators
John McGaw
>I had an acquaintance in Silicon Valley who built his own window operators from simple DC gear motors picked up at the local surplus store. His were essentially automatic, operated by a temperature sensor but there is no reason it couldn't be done by a DPDT spring-loaded center-off toggle switch. I'm pretty certain that some sort of suitable gear motor might be found at the local junk yard or, failing that, online. The hitch would be making the whole installation presentable. A wooden enclosure around each motor would probably be the easiest way if one didn't have a thermo-forming machine handy.
Bob Lemon Sacramento Ca.
>Jared, I suggest you check with Pella and see if they have an extension piece to add to the mechanism.
