Staining Poplar
Larry
>What is the best way to stain poplar and get a good finish without blotches and get a nice look?
Staining Poplar
Larry
Paint it instead
Re: Staining Poplar *LINK*
Dan Donaldson
>This is stained poplar.
Stained Poplar
NM: Beautiful Work
Paul Leuba
Re: Staining Poplar
Kris Lasure
>If I'm going to stain a piece made from poplar, I pain stakingly find find enough lumber with consistent color throughout. I've had really good luck with water based dyes followed by shellac and your favorite finish. I've done a couple pieces years ago like this and the finish and them looks great.
Otherwise, as a couple others mentioned, paint it.
kl
3 coats of Zinssers Seal Coat shellac............
Art Silva
>will give you a moisture barrier of 87% on a scale of 100, and that will allow you to use a solvent based Gel Stain to make it look like any wood you want without any blotching. Put your Gel on with the grain with cloth, paper, foam or brush. Actually, any shellac will give you the same barrier affect, but de-waxed Seal Coat allows you to put anything over it. You don't have to sand the shellac.
Shellac has been a staple in the wooden boat business for ages, and the advent of Seal Coat has enhanced its use immensely. Good luck. Art
Re: Staining Poplar
Hal Smith
>What kind of stain did you use Dan; i.e., water based, oil based, dye?
If not dye, why shellac before the water based poly? TIA. Hal
Re: Staining Poplar
Dan Donaldson
>It was an oil stain. I used the shellac just to be sure that I had a surface that the water born poly would stick to.
