Veritas - Innovation in Tools
need every1 opinion
need every1 opinion
need every1 opinion
edward mccormack
>Hello all,
If someone could give my an opinion as to whether this is safe. Still recovering from the tble saw mishap im a lil' weary of this. What i need to do is finish a kaleidoscope for my wife, not having a leathe i would be using sandpaper strips, rasps and files. thank you.
Ed9 1/4
http://www.instructables.com/id/Drill-Press-Lathe/
Re: need every1 opinion
Dave Bonde - Iowa
>I guess you could use that setup safely, others might have some comments or suggestions about the setup. The 2 points I want to address are 1) the strips of sandpaper you mentioned. Do NOT hold the 2 ends of the sandpaper together in one hand, the paper can wrap around itself and pull your hand (or fingers) in. 2) having the chuck on the bottom spinning is and area that could grab a sleeve or watch so be aware of that.
Dave
>I've got a lathe. Lathes have nice adjustable tool rests, a headstock and a tailstock. A lathe would be a safer way to go.
A different alternative would be to make a shaving mule or shaving horse and shape your piece with spokeshaves, rasps and sandpaper.
Email me off-line and I'd be happy to make the piece for you.
