Have a question? Ask Woody!
wood handles
wood handles
wood handles
Mary Plott
>I am very new to wood working. We want to make a handle for a BBQ tool. The handle is in three sizes, 4 1/2", 5", 6" and made of 3/4" dowel rod. We want to make a very simple grove around the handle and need to drill a 1/8" diameter, 2" deep hole in the end for a stainless steel rod. Can the 2" hole be drilled while the stock is in the wood lathe or do we need a drill press?
Thanks a lot
Re: wood handles
Depends on the tools you have
Dustmaker Mike
>yes you can drill the 1/8" hole on the lathe if you have the blank in a chuck and a drill chuck to put in the tail stock. If not it is easy enough to drill it on a drill press. As for the grove around it I would use a 16 penny nail and press it into the wood while it is spinning on the lathe. CAUTION use the the tool rest to help guid the nail. Point it down and get the feel of the grab on the wood. But that is just the way I would do it. Have Fun
