Any Problem Using Dado Blade ....
Joe in Tallahassee FLA
>... with say only one outer blade and one chipper? I need to plow a groove that is less slightly less than 1/4" for accepting imported 1/4" plywood.
Thanks,
Joe
Re: Any Problem Using Dado Blade ....
Charles M
>I can only speak for Freud dado sets, but yes, there is a problem. Running a dado set with out both outside saws puts uneven stresses on the blades which can lead to damage and potential injury, not to mention the poor cut quality. Outside saws should always be used in pairs and the chippers should never be used without the outer saws.
Charles M
Freud America, Inc.
>I wouldn't do it. I don't know about your stacked set, but my stacked set has a little bit less that 1/4" when the two outer blades are stacked together.
Have you considered an undersized router bit? They make plywood sized router bits.
John E in SC
>Also wouldn't do it. I'm pretty sure you would have unacceptable tearout on the chipper side, and without the full diameter of the blade to support the side of the chipper, I'd be worried about it rotating and damaging your other blade (while making the dado too wide in the process. If the two blades together without chippers is too wide, I'd use a router bit, or you could always make 2 passes with one blade, if you adjust your fence carefully.
My 2 cents.
John
Bart Goldberg
Bart Goldberg
>I'm with john - use a single blade, adjust your fence and make a second pass.
Bart
What I do is
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Take two 7 1/4" saw blades of the same make and number of teeth. They can be shimmed apart with cardboard disk, to fine tune the width.
>Thanks, Charles. That's what I thought. Since I use Freud dado sets, I can imagine a better source.
Joe
>Got the router bit on order. It will actually work better for me since I may need to stop the dado just short of the end of the board.
Thanks,
Joe
