Help me figure out how to make these frames
Tim Greif - West of Chicago
>LOML really likes the look of these super-wide picture frames. She wants to try a grouping of them in a guest bedroom. I figure they're plastic or some sort of "non-wood" material due to the lack of much thickness. I though of trying to make them out of wood and painting to match the picture but I'm have a real problem figuring out how to do this. The frames assembled look to be at least 20" across.
I was thinking of two strips of solid wood behind a plywood face. The strip at the frame center would be offset about 3/8" to create the rabbet inset for the picture. The strip at the outer edge of the frame would be deeper to give the frame its taper outside to inside. Then true everything up to the wall by making a couple passes on the edges on the table saw. Am I on the right track? Anybody done something similar.
Re: Help me figure out how to make these frames
Dave Mount
>Since they will be painted, I would make them out of MDF. Paints better than wood and won't move.
Rather than cut down to this profile from larger stock, I'd build it up from pieces. I'd make the show face out of thinner material, and build up the back by gluing wedge-shaped strips to the outer and inner edges so both the outside and inside are flat to the wall. Once the stock is made up, you can just miter and glue, maybe stick in a spline or biscuit to reinforce the joints.
My $0.02,
Dave
Al Stokka - Cambridge, Iowa
>Tim,
They look like they could easily be made from a length of cedar siding cut to length with miters, splined, glued, sanded, and painted.
Iffn you want to skip the sanding, start with a piece of beveled hardboard (ie: Masonite) siding.
Al
Sgian Dubh
>I'd avoid using solid wood Tim. Here's an example of what could happen. I mitred and biscuited together two assemblies out of European beech, see below. The assemblies were approximately 300 mm (12") square meaning each piece of wood is about 150 wide from the centre point to the edge of the square.
As you can see from the Post-It note the MC was about 8% at the time of construction.
One glued up assembly was kept in the house by a radiator. The other was put out in my garage where it was cool and damp. After 16 days in these conditions I photographed the end result again.
You can see the result of moisture loss, left, and moisture gain, right.
I did this exercise to illustrate some text I'm working on that describes wood movement and the problems that can occur if the movement's not properly allowed for. Slainte.
Ed Mulligan, Cape Cod
>Tim -
I�d definitely use splines to aid with lining things up when you are gluing the thing together.
I�d make the frame material wedge-shaped in section. This has two advantages. First, the miters are simple 45 degree cuts instead of compound miters. Second, I think having the back flat will help during glueup.
For glueup, you will probably use a band clamp. I don�t know if this will happen but if the face bevel gives the frame a tendency to collapse inward when the band clamp is snugged, you could sandwich the frame between two pieces of mdf and clamp them together. Secured that way, the glueup has to be flat and square. If you want to see what�s happening to the joints inside the sandwich, use thick acrylic cauls instead of mdf.
If you want the back to have a bevel, make it with a flat back as above and then cut the bevel after the glue has cured. Watch out where you cut so you don�t expose the splines.
Ed
