>Instead of mobile bases, I am looking at some casters to install directly to some of my tool stands. I found a recommend for an E-Bay source (100% satisfaction history over 650 customers) that offers poly-on-poly (polyurethane on polyolefin) and rubber-on-poly (rubber on polyolefin). Stemless poly/poly is $4.95, while rubber/poly is $5.45. Each is rated at 250#, and would be used in sets of 4 on fairly lightweight items of 150# or less, probably "less."
Tools would not be moved regularly, but rolling beats dragging any day.
What are the advantages/disadvantages of the two materials?
>The rubber is usually "softer" and provides an "easier" ride - at least that what was told to me. I don't know if it makes that much difference if you aren't going to moving them much. The rubber might deform a bit over time.
Take a look at this chart and the associated notes to help you (it's amazing how many options there are). It's my impression that, assuming you don't have oil, etc., on the floor of your shop, and the weight rating of your casters is at least 2x the actual load, the main worry is getting the wheel material to meet your needs in terms of resistance to movement, protection of the floor, etc. For industrial applications it appears that there are multiple other levels of considerations.
