My Mortise 'Machine' (long w/ pics)
Joanne Adler in Pt. Pleasant, PA
>We�ve had several posts lately about the various mortising machines out there and which ones are good choices. I would love to have one, since chopping mortises by hand is not my best skill, nor am I very quick at it. But a mortise machine is not in the budget right now. For the holidays I had wanted to make some plant stands for some friends (and one for my mother�s birthday--she got the 'prototype' last Fall and loved it). I had seen them in an old magazine (Woodsmith, I think). That plan called for loose mortise and tenon joints and to make them, the magazine also printed a plan for a mortise jig for a router. Hmmmm. I have a router . . . .
The jig is basically a box with a top with movable stops. You make a new plexi rectangular base for the router. There are 2 big holes in front to allow for clamps to hold the workpieces. With this jig you can rout mortises in flat grain or endgrain and even on angles. You can probably make a jig even more precise and figure out how to make an extension so you can use stops for the workpieces to speed up production. If you�re paranoid like me, you�ll draw out every mortise on the wood.
Here�s the full jig and what the top looks like (no--this is not an ad for Festool; I also have a Bosch router, but the Festool has better dust collection and sits politely without tipping over when connected to a vac hose):
And here�s underneath�you can see a U-shaped bracket that helps hold a horizontal piece under the top. The other bracket is for vertical pieces and mortising endgrain.
Here are some of the legs with multiple mortises in the long grain. I would like to figure out a way to make extensions with stops to set to make doing long pieces easier.
With the vac hooked up to the router, here�s my FAVORITE thing about this jig�very little mess!
I forgot to shoot a picture of the little tenons I cut, but I took one long piece of stock, rounded all edges with a router or plane, and cross cut little, loose tenons. Here�s how a stand came together, before the top was tiled:
The original stand I saw in the magazine called for one big tile in the top. Nice, but a bit boring. My good friend, Bebe, is a potter and makes tiles (among other wonderful things). She tiled the tops for me. We put a stock 4� tile in the center and she used little ones around the outside to make these special gifts for my band (No Windows). They came out great and were a huge hit as presents. Of course, no one wants to cover up any of the tiles by putting a plant on top; they�ve put vases or other small works of art. Fun project. Cool jig.
Re: My Mortise 'Machine' (long w/ pics)
Re: Nice work! Please put in the Articles....
>section!
>Good Afternoon Joanne,
That is a very clever, very well constructed jig, which also looks great. Its a real credit to you and Fred. :<)
George
Re: Nice work
North of the Border
>I used to route mortises with a router (actually on my router table as there's no need for any shop-made jig), too. As my budget allowed me to do so, I got a (Delta) mortising machine and boy, once I started doing mortises on the dedicated machine, there's no return. The router indeed is a very versatile machine that allows you, among things, to do planing, (rounded) mortising, etc. But if one day you can afford a mortising machine and do a lot of mortise & tenon work, a mortising machine is highly recommended.
Nice! and questions
Bill Tindall, E.TN
>I don't know if I am more impressed by the jig or the stands. I may be tring to make both.
I'm a bit slow. What is picture 2 showing? I am not certain how the stop blocks on the top of the jig are adjusted.
Jesse Cloud
>Way cool! Love the ample room for clamping. Like Bill, I don't understand how the stop blocks work - please elaborate.
You know, with a way to put a strip down the middle of the hole in the top, you could do tenons, too!!
And don't you love that Festool router! I can have my Festool router making sawdust while I stil hunting for tools to set up the other router.
Thanks, and Answers
>The blocks you see in the first and second pix slide on runners. You make a rectangular plate for the bottom of the router and it goes in the space between the 4 blocks. You adjust them so that you can move the router left to right (or front to back) to rout the mortise. They serve as start and stop blocks for the rectangular oversized router base. For the mortises for this project, I kept the front and back blocks snug to the base and had the left and right blocks set for the the distance of the mortise, based on the width of the router bit.
I suppose, as someone else suggested, you could do this on a router table, but that might make me nervous. I've thought I might build a horizontal router table that would make routing mortises easier, but this looked like a fun project, so I built this instead.
still more questions
Bill Tindall, E.TN
>I am pumped about building one of these. Unlike the person suggesting you buy a mortising machine, I have one and want to go to the speed of floating tenons.
In picture 3 is the piece of plywood under the clamp illustrating where the legs got clamped for their mortises?
Could we have an end view?
Still more answers
>Bill,
Yes, the plywood at the top is the test piece I used to cut the mortise you see in the 2nd picture. The big U-shaped bracket with the slits holds the work piece up under the top, at the hole. The clamp holds it against the box so it doesn't move forward.
I'll shoot an end view of the box tomorrow for you and find the issue number of the magazine it was in for you.
Jim Shaver Oakville, Ontario
>Hi Joanne,
I know we spoke while you were making this jig, it's perfect in every way, look at those plant stands, they are amazing in that they have been made so cleanly with that jig! Nice Festool promo too, I have desires to try one some day...bet it would fit well in my shop too,
Great post, your work looks wonderful and thanks for posting!
Take care,
Jim
Re: Side shot
>Here's the side view Bill asked for. The "ears" on the bottom of the box are for clamping the unit to a bench. I think one of the first pictures shows that.
The issue of Woodsmith this appeared in is Vol. 25/No. 147.
Consider It (about to be) Done. Great Jig!
Garrett in Victoria
John in Calgary
>I built one of these a few years back too. I used mine to make both tenons and mortices.
The biggest problem I had was setup - how to make sure your mortices were where they needed to be and how to make sure your tenons were the right thickness.
The second biggest problem I had was with reference faces - I don't own a thickness planer (yet), so I had to make sure I picked a reference face on each board, then make sure that I placed that face against the jig, otherwise my mortices wouldn't always match up.
My first try was for replacement legs for a toy cradle, I went through a lot of trial and error trying to get it right before my FIL pointed out the reference face thing. My second try was for an arts&crafts-style gate for the back yard - it went much better. The good new is that in the 3 years the gate has hung, it hasn't sagged yet.
If you decide to cut tenons with the router, I found that a rasp made quick work of rounding off the tenons to fit in the oblong mortices.
John
