THE WOODRAT IS BACK!
Construction safety question
Larry Marker
>Pardon what may be a pretty dumb question -- I'm an electrical engineer, not a mechanical or civil engineer.
I want to hang a 20 lb air hose reel from the ceiling in my basement. The joists are 2x10's on 16 in centers. The basement is 24 ft wide with a center beam, so the joists are 12 ft long. I want to hang the hose reel about 3 ft from the center beam.
Is it OK to drill holes through the joists to mount the reel? I'm talking about two 1/4 in holes about 8 in apart in two adjacent joists to bolt a plate to hold the reel. I assume it's better to drill near the top of the joists so the holes are in compression rather than near the bottom where they would be in tension.
Am I concerned over nits, or is this actually a bad idea?
Larry
Re: Construction safety question
>Electricians and plumbers routinely drill holes in floor and ceiling joists for cables, conduit, and pipes.
I don't have my reference book in front of me, but you can drill a 1/4 hole nearly anywhere on a joist. In general it is best to stay away from both the top and the bottom. The attached drawing illustrates where best to drill holes.
Larry Marker
>Excellent -- thanks for the drawing.
Larry
Kevin Rabenaldt
>Remember also, you can attached additional wood to the joists with constructive adhensive or screws (you got screw holes!) and then attach something to that. 1/4 inch holes, as said, is so small, it does not affect the strength of the joist. The real problem is 3 inch or 6 inch holes in the wrong place that plumbers and HVAC subs do. If the joists are sized correctly, there is a good safety factor already built in. I sorry to admit as how much I hang from ceiling joists in my garage.
Kevin
Larry Marker
>Thanks -- I know about the sister joists, but didn't think they would be necessary for small bolts. However, I haven't really studied wooden beams much and thought I'd seek some wisdom here.
I wound up using 5/16th bolts, but they are still small relative to the size of the beam.
Hose reel is mounted and life is good...
Larry
