>An unsolicited contribution to ShopTours.org prompted me to catch up on any tours that happened to have been posted to Shop Shots by mistake, and I wound up with three new tours and an update. I'm also working to improve the backend over there, too (eliminating tables and converting to pure CSS), but it'll mostly be transparent to the user. Immensely satisfying, however, except when you run across errors which have been sitting undetected for three or four years. That's annoying—discovering them and then tracking them down. CSS ain't HTML when it comes to troublshooting.
>I remember looking at this once but I haven't for a while. Thanks for the reminder.
One small problem. I've switched to the Firefox browser with the tabbed interface. When clicking on a photo, the photo opens in a new tab. Subsequent photos reuse that same tab. To browse the photos requires constantly closing that tab or switching back to the earlier tab to select a new photo. With IE 6 (no tabs) it is a little easier since the first photo opens in a new browser window and each subsequent photo reuses that same window - I can drag the photo window to my second monitor and click away on successive photos in the main browser window.
I can't figure out how to use Firefox gracefully to view these photos. Is there a better way?
Seems like it would be easier to use if the photo simply reused the main browser window allowing a "back" to return. (I use a mouse with a separate "back" button.) What would be even nicer is to steal the code WC uses to open a photo in an overlay window with a second click to close.
Well, John, you raise an interesting point. My first reaction is, how do we hit the moving target that is everyone's personal mode of operation? I'm pretty sure the answer is “we can't,” so in an attempt at mollification, let me at least explain why it is the way it is at the moment. When I wrote the code for image handling, there were no tabbed browsers, of course (my primary browser then was Netscape—it's now Firefox), so the process in those days was exactly as it still is for IE6 (the infamous broken browser).
Personally, I always liked having the separate window for the large images, although Jakob Nielsen, a sort of website usability guru, hates all popups, whether utilitarian or not. I generally heed his counsel otherwise, so I may have to revisit this whole thing in that light and in the light of modern tabbed browsing.
I can't either, and I guess I'm going to have to face the prospect of finding one.
My trackball has that feature, too, and I never realized how dependent I'd become on it until I sat down with a regular mouse—positively, excruciating. I'll have to look at how WC does that. If it's a simple HTML or CSS process, I'm not above lifting the technique (how 80% of the web is written), but if it involves Java or other supplemental coding, I'm not that far along in my own development yet.
You're making me rethink the advisability of continuing the CSS rewrite I've just started, as I'd rather go through the hundred or so files once, rather than twice, although I think I might be able to make the graphic handling change globally, depending on how it's implemented.
Thanks for the stimulating feedback. I hope I can develop a good presentation suitable for your needs.
I don't know how feasible it is to implement (when I was a software designer/developer I never did web work), but one nice way to handle things is with user preferences. A check box for "open images in new window" would work but perhaps at the expense of handling a cookie.
I hope to have some shop tour photos myself someday. Those of my current shop would elicit only sympathy or ridicule. :)
>John, With FF you can use CTL left click on a link and it will open in a new tab. You can go down the list opening as many tabs as you like. I use this method when viewing the lists and usually just hold down the ctl and click on and open maybe 20 tabs/links. You can then view or read the link and close that tab.
>>...you can use CTL left click on a link and it will open in a new tab
Stuart,
Well, the point was it already opens in a new tab! That seems clunky to me since it then requires a extra mouse move and a click to get back to the shop page. (There is, however, a way to close the window using the keyboard instead of the mouse.) Returning to the shop page by means of a single click (with no mouse pointer movement needed) would be quicker and more efficient. (When I was a software developer one of my specialties was user interface design. :)
BTW, there are also other ways to open a link in a new tab. My favorite is a single click with the wheel button on a wheel mouse since it requires no mouse movement and no keypress. Also, right-click and "Open Link in a New Tab" from the RC menu does it at the expense of a small mouse movement. Ctrl-click is my least favorite since it requires moving one hand to locate and press the control key and then click.
BTW, if it seems a little extreme to go to all that effort to consider small additional mouse movements and extra clicks, just watch someone with extreme mobility limitations use a computer for a while! I have one quadriplegic friend who cannot press a key on his keyboard without fastening an implement to his hand. He uses a trackball since his hands cannot move a mouse or press a mouse button. Every motion requires a concentrated effort. Even those of us with severe hand/wrist pain can often benefit from a little streamlining.
Rod,
It doesn't help much in the big picture, but I did remember a workaround using the keyboard that works great for me! I use this a lot with Photoshop and other applications but tend to forget about it with the web browser: While browsing the photos, keep the left hand near the keyboard. After viewing a photo, press Ctrl-F4 to close the tab and return to the shop page. Works very well with Shoptours.
The bad part is it's not a comfortable keypress stretch for most people. It works great for me since all my keyboards have the function keys down the left side as well as on the top. With the side Fn keys, I can easily press all combinations of every function key with Ctr/Alt/Shift modifiers with no hand stretching. Since keyboards like this are hard to find, I bought a life-time supply about 15 years ago. When my last keyboard breaks, I'm through with computers! :)
(While I understand the reasons, I consider moving the function keys from the side to the top was orchestrated by Satan himself, driven by corporate greed, and justified by accountants instead of efficiency studies. Same thing for the inverted-T cursor keys. Evil!)
I don't have to go that far. All I have to do is try to work my 88 YO, half deaf, half blind, non-touch typist mother through a computer situation over the phone. Even <Shift> <anything> requires she put the phone down—it is impossible for her to do it one handed. Add to it that she's a mad clicker (when not getting an instant response from a mouse click she figures another one or two or three will make it happen), and you can see that my life solving her computer anomalies is pure misery. SWMBO has to leave the room when I'm on the phone with her because although I'm apparently very patient to her, SWMBO can sense the frustration and irritation in me. It's very uncomfortable for her—she gets enough of that when it's directed at her…
I have two words: Northgate Omnikey. I got turned onto them at least 15 years ago. Built like a tank, best key-feel of any keyboard ever, and Fn keys on the left (XT style) as well as the top (AT style). Sad that they went out of business, but if you can stand the vigarish, there are a couple of sources for similar keyboards out there.
I got turned on to the left side Fn keys when I was actually using XTs. Seemed perfectly reasonable. When the ATs came along, I couldn't understand why manufacturers had moved them. As I was using my computer a lot for radio contesting at the time, the software packages for which were all Fn key rich, I just kept using my XT keyboard until I discovered the Northgate. Ultimately, I wound up with four of them, all of which have developed quirks. My current one doesn't have a function equal key on the top row. Fortunately, the one on the numeric keypad still works, but it's, as you say, an awkward keystroke.
There are a couple of Northgate repair folks I've found on the web—I'll eventually get one or more of these brought back to complete life, but whatever computer my heirs wind up with, it's certain to have a Northgate attached to it.
And, by the way, the most valuable computer gadget I own is a DIN to PS3 adapter. I'd be interested to know if this thing will work in a USB port.
>I've had some Omnikey keyboards before. Years ago I bought up a supply of programmable Amykey keyboards from Gateway. These have a full numeric keypad, a full cursor keypad, dual Fn keys, and the ability to reprogram any key to swap or add macros. I've had the one I'm using now in service for so long I've worn the little indexing bumps off the keys and the characters are worn off lots of the keycaps.
I reprogram several keys: the caps lock is banished, I add an Esc and Ret just to the left of the space bar, and put Ctrl, Shift, Alt in a vertical stack immediately adjacent to the function keys. This lets me quickly access all Ctrl/shift/alt combinations with both the Fn keys plus most of the alpha keys on the left side of the keyboard, all with the left hand, without looking at the keyboard, and without the need for hand gymnastics.
When I was doing 3D graphics and animations 10-12 hours a day, I kept my left hand on the keyboard and my right hand on the mouse. With many functions programmed to the keyboard I could run circles around others using the same software. Video editing is another task that is far more efficient with the keyboard instead of the mouse.
I also pry up the keycaps and rearrange the cursor keys to the legacy keypad configuration which makes a LOT more sense than the inverted T. I used to have little labels on the reprogrammed keys, but they've all worn off - this frustrates anyone else who tries to use my computer!
The down side of this is when I use someone else's machine or a laptop it's like working with an amputation. Fortunately, I always worked from home with my own equipment and could control things to suit me.
I think the biggest reason for moving to the upper row of Fn keys was to save money, although reducing desk space was also an issue. Keyboards could be made smaller and more compact and cheaper. I believe the configuration was originally proposed so the Fn keys could work as "soft" keys with labels displayed across the bottom of the monitor placed just behind the keyboard, but this didn't catch on widely except in turn-key commercial/industrial packages. Most people don't touch type so who cares if they have to look at the keyboard to hit a function key. Also, with Windows for the masses, few people today learn the power of using the keyboard for control. What they don't know, they can't possibly miss. Sigh.
I've had limited success with keyboard adapters.
I use a single keyboard, mouse, and set of dual monitors on several computers with a KVM switch box. The trick was finding a switch box that would handle dual monitors. I've had as many as four machines connected to this one (MegaSwitch) but I'm down to two at the moment and don't really need the second one. I LOVE the retirement thing!
BTW, if you haven't done so, you might take your keyboard apart and clean the key contacts on the printed circuit board using a cotton q-tip with rubbing or denatured alcohol. Most of the time, that's what goes wrong. (I had to do this with my cordless phone the other day.) I once had a "buggy" keyboard - turns out some tiny insect crawled inside and left a piece of wing that prevented proper contact on one key!
Sometimes, the mechanical bit sticks and needs a speck of silicone grease on the sliding parts.
>John, I wonder if you might like gestures. I don't use them myself, I use Ctrl-PageUp and PageDown or the mouse to change tabs, but changing tabs and stuff is one of the prime jobs they list for the add-on.
>I get by using Firefox with tab mix plus and a logitech revolution mouse. The mouse has 10 buttons and I have them programmed to do most all of the common tasks. (forward/back, close tab, change workspaces, etc.)
