OT–Geeky HTML stuff—Freaked out!!!
Rod Peterson -- Ormond Beach
>Warning: Unless you're morbidly interested in seeing me flop around helplessly on a technical HTML issue, back out now. Incredibly geeky stuff follows. Don't say you weren't warned.
Okay, Dan, Ellis, Mark, other web developers, this is freaking me out.
I'm working on some Shop Tours stuff, and I've redesigned the template to use CSS instead of tables for layout. More to the point, all of the code used for the last several years has been thoroughly reviewed and in the case of the latest edit, rewritten, by me. What I'm trying to say is that I've had a hand in originating all of the markup being used, and I'm thoroughly familiar with what's in it and what it does.
Part deux: I've implemented favicons on my own webpages, and have a fair idea of their use—they're called in the header with a line which specifically addresses filename.ico, an ico type graphic. I've had to create the graphic using an outside web source which returns a specific .ico for the image I uploaded, then the code calls the graphic for presentation.
Part trois: the template for ShopTours.org has thumbnails of all of the shop images along the left edge and text adjoining them on the right. Click on a thumbnail and a new window/tab opens up to display the larger graphic. Basic stuff—hasn't changed since Badger Pond days, and the call for the new window/tab is a simple parameter in each thumbnail anchor element labeled (in this case—doesn't matter what the label is) newindow.
Part quatre: I have no command in any of the individual shop files to call a favicon graphic. Fred had implemented it for the site a few years ago, but so far as I know, he managed it from the server side (I don't know how)—I know he didn't go into any of the specific files to add code.
Freaky part: today while creating some new tours, I noticed that whenever I clicked on a thumbnail, the image would appear in the new window/tab (nothing earth shaking there—that's how it's always worked), but on the tab (and in the URL box), it displays a favicon of the image displayed in the tab!!!! Different image, different favicon.
How is that done? Moreover, and I guess this is the really freaky part, it's doing this locally on my computer, and it's doing it dynamically. Whatever Fred might have done on the server is not involved. Can anyone explain this to me?
I can assure you there is no code in my template that should do this (because I'm not smart enough to have written it). I'm so confused.
Rod
