Veritas - Innovation in Tools
Dado's in Europe? How do you do it?
Brian in Brighton
>Sgian Dubh was saying in a different post that the table saw arbors on European table saws are too short to allow a dado blade. So how do you make dados? Router tables? Or is there some sort of dedicated dado saw? If it's on router tables, how can that be efficient in a production shop?
Brian in Brighton
Re: Dado's in Europe? How do you do it?
Sgian Dubh
>It's not hard, especially in large workshops. We use CNC machinery, overhead routers, spindle moulders, hand held and inverted routers. For housing and trenching work, aka dados, we can also use radial arm saws (RAS), and dado blades are permitted in these machines. However, radial arm saws used for this kind of work tend to be honking great beasts with plenty of power and pretty good rigididty.
At the home workshop level a T square (or other specially devised device that's similar) and a hand held 2000 or 2,500 watt router makes quick work of the job. This is preferable I think over sliding a long thin bookcase end cross wise over a dado blade with the end of the panel butted up against the rip fence-- I've seen that trick too often and it always gave me the heebie-jeebies. I know there are better and safer methods to use a dado blade to cross cut with a saw, but speed was sometimes favoured over safety. Slainte.
