OT Computer Questions
tom norton
>If computers were made out of wood I would be set!
My wife and I are lookng to upgrade and I have a question .I see that most coputers come with a DVD that is a player and will allow you to write to the DVD. Am I correct? So will this same unit also allow you to use a CD? I down load cd's to WMP.
Thanks
Re: OT Computer Questions
Ken Oakley-Sunny St. Cloud, Fla
>My Dell does-----I think they all do if equiped with the DVD/CD drive
ebd
ebd
>Any DVD burner should read & burn CD's as well.
John McGaw
>It is best to pay careful attention to what is being offered. The range of optical drives, even leaving high-definition out of the mix for the moment, is wide. 1) CD-ROM which reads CDs only 2) DVD-ROM which reads DVDs and CDs 3) DVD-ROM/CD-RW which reads DVDs and reads/writes CDs 4) DVD-RW which reads/writes both CDs and DVDs. Numbers 1 and 2 are almost extinct now but you might still see number 3 in very low-end machines. Number 4 is probably the most common now but even then it pays to read the specifications carefully to make sure that the drive can read and write DL (double-layer) DVDs which offers more flexibility about length/quality of DVD burns.
I'm in the middle of copying all of my old VHS tapes to DVD. A very long and tedious process but one which gives me time to think about the quality of drives being offered now. Prices have dropped dramatically for DVD-RW drives over the past few years. The one in my most recent build cost me all of $32 and does everything short of high-definition and does it well while the one in my build-before-last cost nearly $200 and did less although the physical unit seems more robust. Whatever you buy it would be good to verify what version of the maker's firmware is installed on the drive and to keep it updated since the better makers seem to upgrade capabilities and correct problems on a regular basis. Don't assume that a drive in a new computer will have the latest firmware.
Jerry Nicholson
>You need a good CD/DVD burning program to go along with your new CD/DVD burner. I like Nero but it has gotten to be kind of expensive. The CD/DVD burning capability that comes with Windows is very minimal - not because Microsoft couldn't provide a good burning program but because they would be sued (yet again) by Nero, Roxio, NTI, et. al. if they did so.
Jerry
Bill Howatt
>If he buys a "retail" boxed drive it likely has Nero or something included, often a basic version which is plenty adequate for most people.
Even if he gets the drive at a corner mom and pop computer store in the OEM version without the fancy packaging he likely can get a Nero CD from the store for next to nothing.
Bill
Jerry Nicholson
>I was assuming he was buying a new computer but you are correct - ever CD/DVD writer I have purchased in the last 10 years (a bunch of them, actually )has had at least a stripped down version of Nero, Roxio, or NTI.
Jerry
Re: Nero
Chuck W
>Not only has Nero gotten expensive it also is trouble prone and it, in my opinion, become something like Norton in that it tries to do too much and does not succeed. And if you had Nero previously on your computer and try to load a new version it will block until every last bit of the old version is gone. This means you need to get a "cleaning program" from the Nero website, run it, and hope that, now, the new version will install. I would not buy Nero again. Instead I will search for a simpler program to do the same thing.
Re: Nero
Jerry
>I had no problem at all upgrading from Nero 7 to Nero 8. Your problems with Nero are exactly the problems I had with Roxio that made me change to Nero in the first place. After that last Roxio install it took hours to get all the pieces out of my computer and I talked Best Buy into giving me my money back on that one! Nero 8 is probably the end of the line for me - it's priced higher than it is worth now. There are some free burning programs but I haven't tried any of them in Windows. K3b works fairly well on Linux but I like NeroLinux better.
Jerry
