Re: Sprung joints...what gives?
Sgian Dubh
>When joining narrow boards to make up wider slabs the traditional approach is the plain edge or butt joint. This is a good place to start because it helps with understanding other methods. It isn�t really an easy joint to prepare, and like every joint, proper preparation means reduced risk of failure. The idea is to prepare two edges that abut perfectly all along the length so that no pressure is required to close a gap. In practice, this is difficult to achieve and most workers aim for a �sprung� joint.
The sprung joint has an evenly graduating gap produced that's widest at the centre point of the joint line of the two boards. After preparation very gentle hand pressure should be enough to close up two adjacent boards. When cramping up several well prepared boards in one go it is sometimes possible to close up all the gaps with one centrally located cramp.
The sprung joints helps counteract the comparatively volatile width expansion and contraction of the last 50- 100 mm (2- 4�) of a plank�s length. The end grain of timber absorbs and gives up moisture the most rapidly. During glue up of the sprung joint, the ends are closed just a little tighter than the middle, and this helps to compensate for the disparate movement.
In addition to this, custom and practise show that where the two joined edges are convex at glue-up the joint usually fails fairly quickly. In this situation bringing the edges together requires firm clamping pressure at both ends to close the gap. The joint will close, but both ends of the joint are under tensile stress and want to open up. As soon as a slight opening begins at the very extremity of the joint it�s my experience that serious failure soon follows-- a gap anything up to a few inches long extending towards the middle of the length develops in just days. The worst case is complete failure of the joint.
A sprung joint. The gap is somewhat exaggerated here for clarity. When joining boards up to about 800 mm (32�) long the ideal gap at the mid-point should be about the same thickness as perhaps a cigarette paper. Longer edge joints tolerate a slightly wider gap. The ideal gap is one that will close with little or no more pressure than you�d need to hold something like a downward facing telephone directory with fingers and thumb either side of the spine.
The sprung joint on the other hand is much more durable. When formed correctly both ends of the joint should remain tight. Even with the greater volatility of expansion and contraction at the ends of a plank a gap doesn�t form. I use a zip as an analogy to explain what goes on. Close a zip and lock the tab at the end and the zip stays closed. Pull up the zip and leave the tag unlocked and the zip gradually opens.
Slainte.
