Veritas - Innovation in Tools
working with MDO
working with MDO
working with MDO
Carol - now in NC Nebraska
>I have to build a garden sign for one of my churches. I have found a source for MDO locally. How does one seal the sawn edges?
Re: working with MDO
Re: working with MDO *LINK*
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I suppose you could glue and staple or brad on a 1/4" or wider solid wood edge, with waterproof glue.
Another route may be to use extira MDF also. DId you ask about it?
http://www.extira.com/pageBuild.asp?PageID=B_extiravmdf_e
>What is available locally is MDO. Because we are much more than 100 miles from a supplier of something else, and with the price of fuel, we need to use what is available. MDO, according to Norm, is a good exterior material often used for signs. My understanding is that it is a type of particle board with a paper face, but better suited to exterior applications, like signs.
My concern is when you cut particle board, like MDF, the edges are more susceptible to moisture. My suspicion is the MDO may have the same characteristic.
So the question is, has anyone here used it? Do the edges need to be sealed in some manner? With what? Thanks.
Re: working with MDO - I stand corrected
>I got some info back from another site.
It is plywood with paper resin faces. Bondo is used to seal the edges.
It is the paint protocol that surprised me and that is expensive!
Thanks, folks. If you have anything to add, based on experience, I would more than happy to hear it.
Mike Fitterling
>My columns on our veranda were made of MDO and nothing was done to seal the edges except of course to paint them along with everything else. They were as good as new after several years, that is, until the hurricane blew them over the roof of the house and into the back yard.
John McGaw
>MDO is exterior plywood, usually of very good quality and void-less, which has the equivalent of waterproof MDF as the outer plies. Very heavy stuff. Almost glassy smooth surfaces, Paints beautifully. When I tried it out I found that the exterior was pre-primed.
For edging on mine I simply glued on hardwood strips. My project was for interior use but I guess that for exterior the same process would work if waterproof glue was used. All I would worry about would be having water deteriorate the edging -- the MDO is probably impervious to water damage under normal circumstances.
John McGaw
>Yeah. I forgot about Bondo. I had to patch a couple of mistakes on my MDO project and that is what I used for the repairs. It would seem reasonable that one could apply it to the edges to give a smooth waterproof finish there.
Lynn Baker in snowy Glacier, WA
>Carol,
I've used MDO for lots of projects, both indoor and outdoor, and treated the edges with epoxy resin, polyurethane varnish and glued-on hardwood strips. Since the underlying plywood is void-free and the glue is meant for exterior use, the material is very stable and warp-resistant.
The Highway Department uses MDO for highway signs!
Some MDO is sold with the overlay on one side only. I have not used that type but I have seen it.
Good Luck with your project.
Lynn
slight correction on the waterproofness of Bondo
Robin Corell in Atascadero, CA
>Bondo is pourous and is not waterproof. I have used it to fill the edge on particle board and MDF but for waterproofing I then follow that with epoxy or resin. By first filling with bondo the resin will sit on the surface the same as on the faces rather just soaking in. Without filling the edge grain can take three applications of resin before it starts to boild on the surface.
The confusion about bondo being waterproof is that the bondo itself does not deteriorate in water but it will allow water to permeate and will then lose its bond on the substrate. If it is sealed with paint it will last in an exterior application as long as the paint is intact.
Robin
This follow-on point is important.
Howard Acheson
>If you elect to seal the edges with epoxy resin, they must be overcoated with an opaque finish or a clear coat containing lots of UV inhibitor. Epoxy is attacked and quickly deteriorates with exposure to sunlight.
If clear coating, do not use a "big box" brand of "Spar" varnish. They are very poor and short lived. Use a true marine exterior varnish that you get at a marine supply store. It's best to use an opaque paint.
>If you had sealed the edges properly they may not have been damaged by the hurricane.
Howard Acheson
>If using epoxy resin for sealing the edges of MDO, the epoxy resin must be overcoated with a UV protecting finish. Epoxy resin quickly deteriorates with exposure to sunlight. Do not use a "big box" so called "spar" varnish. These are very short lived. Use an opaque paint or a true marine exterior varnish purchased at a marine supply store.
