TS kick back question?
>I have a thirty seven year old Rockwell Delta Contractor TS I bought new and have been using ever since. It has a 2hp motor with the cast pulleys and a link belt. I can not recall experiencing a kick back.
I have had several occasions where the wood had some sort of internal stress and pinced the blade so badly it seized.
Have I just been lucky? Or is the belt slipping and releasing the thrust? Would the kickbacks be worse on a saw with three belts and a more powerful motor? How common are kick backs?
Re: TS kick back question?
Doug Ring
>Barry,
Your experience is exactly the same as mine when I had a contractors saw (fitted with a 1.5hp 110V motor) - if the board seriously warped after cutting, and I had good downward pressure on the board, it could stall the motor. This would be quickly followed by my hitting the "Stop" button ASAP!
Since moving to a 3hp Unisaw, I have found that this motor is literally too strong to stall. There has been more than one occasion that I've had this same event happen, and I just have to double my effort to keep the board passing through the blade until the "tight" section is passed. These are anxious moments indeed...
My only two kickbacks with the Unisaw have been due to scrap cutoff vibrating back into the blade. Fortunately, both times the parts were small and I was not in the trajectory of the projectile. I have two nice dents in my new garage door, however.
>Good Eveniung Barry,
I have been using a Jet contractors saw with an 18 amp motor for almost 10 years, and kickbacks are pretty rare. My saw isn't equipped with aftermarket belts, and the pulleys are stock. I expect some kickback sometime. I decided to keep out of the line of fire. Anytime they occur, and that is pretty rare, I have not been in harms way. Thus far I have not stalled my motor, but I have had the belt slip on the pulleys. I just shut down the saw and flip the stock end for end and continue to rip from the other direction. I've never had to use the reset button. On reflection, I'd rather have the belt slip than have the board fire back at me, or the wall. So, I don't think I'll have aftermarket belts or pulleys on the next saw.
George
Chuck in ND
>Barry, I'd say you've been lucky or wise or you don't have enough electricity running to your saw. Do the lights dim at all when you start the saw ? I've had a couple kickbacks on my Delta Contractors table saw. After a couple I got wise, not saying it won't happen again though.
Steve Schoene
>It is possible to install a good splitter on the contractor saws just as on a cabinet saw. That's a heck of a better solution to reducing kickback risk that relying on motors stalling or belts slipping.
Chuck in ND
>Speakin of spliters, I've looked at the Biesemeyer spliter on the internet, it looks nice but, $160 for that ? It's rediculous, I don't see how they sell any.
Steve Schoene
>I've got one of those and like it quite a bit. It stays aligned with my blades, removes in a moment without tools, and is reinstalled even faster. It was initially installed in a very straight forward fashion, even on my 40's vintage Unisaw. I don't think I paid nearly that much, but it was years ago.
Bies splitter, Me too...
Tim Greif - West of Chicago
>I got one a few years ago. Paid about $110 for it on my Delta contractor saw. I used to cut without a splitter. Then one day, I actually stalled the blade due to case hardened wood closing up behind the blade. I always make a concious effort to have good downward pressure on the piece I'm cutting. My understanding of the dynamics of this is that the wood needs to rise up slightly at the rear of the blade for the kickback to actually occur. By keeping firm downward pressure, you reduce this tendency.
Anyway, after this happened a couple times, I decided to get the Biesemeyer for its convenience and ease of use. I feel much safer now than having to make sure the wood stays firmly against the table until I hit the Off switch. Yeah, it's kinda spendy, but so are a lot of things about this hobby.
Pete in Holland, MI
>Barry -
Kickback has nothing to do with the type of belts/pulleys on a table saw. It has to do with the wood binding on the blade in such a way that it gains enough effort to push it back in the direction it came from. Mis alligned blade to rip fences, wood binding around the blade, or cross cut track to the blade, causes kick back.
If your power system slips or stalls when the blade binds, consider yourself lucky. A more powerful power train will cut wood more, but will have more power to toss your work back at you when you aren't paying attention.
Re: Bies splitter, Me too...
Carol - now in NC Nebraska
>So right, Tim.
And nothing is more spendy than a trip to the emergency room!
I am not sure that $160 pays for the parking place while you are in there. >eek!<
That is my justification and rationalization for spendy safety things.
Uniguard Splitter
Hank Knight
>I put a Delta Uniguard Splitter on my Unisaw and have been very happy with it. It mounts and dismounts easily, without tools, just like the Beismeyer, but it costs less than $40. Moreover, while it's very sturdy, it's somewhat thinner than the Beis and it's compatable wih TK blades - the Beis is not. Prior to installing the splitter, I had two kickbakcs. Both were caused by my own carelessness. I've not had one since installing the splitter 5 years ago.
Re: Uniguard Splitter
Chuck in ND
>$40, now thats more reasonable for something that is that small and mass produced. Now if only a person can find one in that corporate mess that Delta is in now.
Re: TS kick back question? *LINK*
charlie belden
>There are several table saw "unpleasantries" commonly referred to as Kick Backs, and reasons for each. The one everyone thinks of when they hear Kick Back is the Spear Chucking phenomenon - typically the piece of wood between the blade and the fence being hurled straight back along the fence at Mach II. piercing garage doors and sometimes the radiator of the car parked in the driveway.
That one you can stay out of the way of. The Flip and Fly doesn't offer a safe place to stand - except behind the saw - which presents much more danger.
There's the Thin Cut Off Falling Through The Throat Plate - Throw The Throat Plate At YOU thing.
There's the Crossed Legs and Wishbone Kick Back Initiaters and there's the Cupped Board Blade Squeeze sphincter tightener.
Splitters sound like a major step to reducing the risk of the wood at the back of the cut from contacting the teeth couming up out of the table. But they're most effective when the blade is set at maximum height which presents an even greater potential disaster. But with the blade set low - one gullet above the stock being cut - there's quite a gap between the back of the blade and the splitter.
A riving knife set 1/8th inch behind the top rear QUARTER of the blade is far more effective - at all blade heights.
Kick Back - Why?
Ralph Turney
>I started off with a Delta Contractor saw and had a kick back or two, but could stall the motor if I saw one coming. I then worked in a cabinet shop where I had a brand new 3 hp Delta Unisaw and cut a ton of plywood and had the occasion to stall it a number of times. The last thing I wanted was to have a 3/4 sheet of plywood coming back at me, and even though it took an effort I could stall the Uni, and I'm not a big guy. I have a Powermatic 66 at home with a 5 hp Baldor motor in it...don't ask me why I bought a 5 hp, it seemed like a smart thing to do at the time, but I do worry about getting a kickback with it, I don't think I could stop that motor or the belts if I wanted to!
So I spent the money on the Biesemeyer splitter and nothing could be easier to use or remove. I was going to get the whole Biesemeyer guard but got the splitter instead.
Denis Ch�nard, Orl�ans, Ont.
>Just re-read an old issue of FWW where they compared guards and splitters, and the Uniguard splitter worked fine but was only compatible with Unisaws.
DC
