200+ woodworking book reviews
Wooden plaques for painting?
>I've been asked to make some base plaques for the Stations of the Cross.
The plaques will be roughly 20" H x 16" W and I need to make 14 of them.
One of the artist types in the congregation is going to be painting the Stations on each plaque. The scene is going to take up most of the plaque and is going to painted on using oil paints - so not much wood will be showing. Steph says she'll put a couple of base coats of gesso before painting.
My first thought is to use soft maple or poplar - though I can get some red oak at about the same price. So - which wood would be a good base for oil painting? I'll be staining the edges a mahogany color.
TIA
Re: Wooden plaques for painting?
Not a painter but
Dustmaker Mike
>I would think Red Oak to be to course or rough. I think I would stay with the Maple or Popular.
steve mackay
>I mount all my models on red oak stained jocobean. Tried all lot of flavors but the red oak has turned out the most stable after its been stained and finnished. Never had any warp or cupping issues and its been a long time. As far as I can tell, once its stained and finnished it doesn't care what you put on it. Just my two cents though.
>Unless you're going to do moulded edges, why not 3/4" baltic birch ply with banded edges? Or 3/4" MDF or HDF, which could be moulded and given a stain or patinated finish. Looks like an opportunity for some creativity without using furniture grade wood in those dimensions.
Clint
Ken Oakley-Sunny St. Cloud, Fla
>My wife is "one of those painters" and she has about a thousand friends who paint also. I have cut many, many plaques, sign boards etc. for them and have found many of them prefer MDF. It is strong, very smooth and will accept paint as well as wood. The one drawback is it is heavier then most woods. It is available at Home Depot and Lowes, and I guess at most places that sell wood. It is also way less expensive then wood.
Lee Gordon
I'm not an artist but
Lee Gordon
>For what it's worth, the Mona Lisa is painted on poplar.
Did not know THAT one !
steve mackay
So that's why it's so... so.....
>....so pop-U-lar.
Sorry, couldn't resist ;)
Happy Woodworking!
Poplar Met The DiVinci Code., didn't it?
Re: Thanks all..
>I've got some poplar plywood on hand. I will edge band a test piece and see how it works. I may end up going with solid poplar panels - that way I have to do only one glue joint.
Lee Gordon
I should have added ...
Lee Gordon
>I should have mentioned that Leonardo didn't just grab a slab of poplar and start slapping paint on it. The surface was prepared with several coats of gesso (scraped smooth between coats) before any real painting could begin.
