OT: Removing wooden siding
Dan Mitchell
>I've posted here a couple times about issues related to rats in the crawl space of the house we bought a year ago. I've been trying to address every possible entry point, and have eliminated several. While doing some wiring down in the "dungeon", I noted light coming in around where the siding/sheathing meets the poured wall. Below are 2 exterior pictures. The area is a corner, adjacent to the brick fireplace on the left, and is confounded a bit by the concrete base of a chain link fence post on the right. The holes are on the right, beneath where the copper mesh is inserted (a material a bit like a scotch-bright pad made expressly for plugging rodent holes) at the end of the siding. I would like to remove the siding & sheathing in this area, over to the fireplace & up to the 1st full length board, replace the existing sheathing (it's that soft, dark brown fiber-board like material) with something a bit more robust, maybe add some additional framing timbers, etc., just generally seal off the area, then replace the siding. The exact approach will depend on what I find when I get the siding/sheathing off. Anyway, I've never removed siding before, and before I just go out & start prying away, I thought I'd see if anyone here has any suggestions. For instance, should I start by prying off the 1st shorter board under the full length one, or begin with the lowest board? Or is some cutting required 1st?
Thanks,
Dan
