w/ coomon sense "baloney" but in reality.....!
HC Sakman
>...I've tried 3 different sharpening services which all claim they can do the same job. They claim they have the same cnc machine etc... Result: 2 ruined blades and the rest never cut the same as with their original grind did.
Logic says what you said should be correct, but my actual personal experience proves otherwise.
These sharpening services are known to sharpen other brands' blades better than their original state. (I personally know as well as other reliable sources' confirmation.) So, what am I supposed to conclude from this dilemna? I know it's not a rocket science...so what's the difference? Why actual resultd match with Forrest's claims and suggestions?
I think Forrest takes the final grind with very fine grit that most sharpeners don't due to its expense (as I was told by one of the sharpener's in a confession moment) and more importantly, at Forrest, they check and do side (of the teeth) grind, tensioning and balancing for minimal run-out, which is as important as sharpness for very smooth cuts. That's where the difference is....I think.
So, after 8~10 blades I think it's not baloney. Forrest does an excellent job with their blades and in my opinion, nothing else cuts like it. I've tried many others.
The lousiest blade I have ever used is the Austrian made "Felder" brand. My sharpener suspects it's actually Chinese made. What I know for a fact is that not only it doesn't cut nice also it does get dull faster than anything else I've ever used.
Chico...
