I'm here, and here are some answers
Michael Dresdner
>Steve and others got it right. Shellac is indeed acidic enough to eath through steel cans, and for that reason, the cans are lined with epoxy. As some folks pointed out, stirring SealCoat is not necessary, and stirring with metal (I know some people stir with the screwdriver that is in their hand because they just opend the lid with it) can also scratch the thin epoxy lining and cause the problem.
Companies like Zinsser buy their cans from a supplier, and at times, there are voids in the epoxy liner that can result in the pinholes you are seeing. Since they buy large batches at a time, it is not unusual for can problems to come in waves; a bad batch of cans, undiscovered until they start to leak, will fan out across the country at once, and suddenly many problems occur simultaneously. There's not much Zinsser can do but pray that their suppliers are consistent and reliable, but of course, that is a pipe dream in today's world.
When we were working on the now discontinued Zinsser French Polish, I insisted that it should be packaged in a plastic squeeze bottle, but the DOT said that was a shipping hazard and disallowed it. For those of you who recall, the product came out in an aluminum can, in part to ameliorate this pinhole problem.
Switching the contents to plastic will solve the problem. As for the person who experienced pinholes in plastic, I don't know what caused it but it was not the shellac unless the plastic was one that is not alcohol reistant. Most are. What may be happening there is two entirely different issues that coincidentally occurred in sequence. You should have no problems with SealCoat in the right plastic. When in doubt, use Nalgene or polypropylene.
Finally, do get back to Zinsser with these issues. I will call Susan today and let her know that there is a thread going about this, but the only way Zinsser can know when one of their suppliers, in this case the folks who make the cans, is slipping on the job is with feedback from you.
I hope this helps.
