ADVERTISE HERE - FREE TRIAL
OT: Painting over wallpaper
Ken Krawford
>We have a small bathroom that is wallpapered. I have tried to strip the wallpaper with no success. I tried commercial stripper, the little pointed wheel, etc to no avail. It has been suggested that a skim coat of sheetrock mud can be applied over the paper and painted.
I hate to throw good money after bad.
Will this work? Any other ideas?
Thanks.
Re: OT: Painting over wallpaper
>There's a wallpaper product called "liner" that's just plain white heavy paper, available plain or canvas textured. It will telegraph any underlying bumps and gouges. Put it up with vinyl paste and top coat with the finish of choice. It works well.
Clint
Jason Roehl in Lafayette, IN
>Ken,
Yes, you can mud over the wallpaper, but prime it first with white pigmented shellac (BIN and the like), or a solvent-based primer (ick). You don't have to prime and mud everything (unless you want to), but the bare minimum would be the seams of the wallpaper and anywhere you broke the surface of the paper with your attempts to remove it.
Jason (Addy protocol: pro painter)
Steam it off
Tim Greif - West of Chicago
>I've had to deal with walls where folks did just what you're proposing, painted over wall paper. IMO, they should be beaten with sticks. I guarantee you, someone is going to want to fix it right someday, and they'll curse you.
In my experience, the best way to remove it is to use a steamer. LOML does it quite well. Yup, it still leaves some minor gouges and boo-boos to fix with some joint compound, but it's not anything severe. Then just prime with Zinsser 123 and go at it with the paint of your choice. You'll thank yourself later (or at least someone will).
Just my 2�, from someone who's dealt with more wallpaper than he cares to remember.
Re: Steam it off ...agree with Tim
Ray Carson - Lawrenceville, NJ
>I'm in the process now of re-doing my 9yr. old daughters room. Same problem....wallpaper that was put on with Super Glue.
Three applications of DIF, the paper tiger....no luck.
My brother just happens to have a steamer and it was the only thing that worked. These little gems can be rented at the big box stores or local hardware store too.
Yes....the drywall took a beating AND I did curse the person who put me in this situation. I just finished skim coating the walls with the final coat of joint compound last night. I'm using my 6" Porter Cable random orbital sander hooked up to my Shop Vac to sand the walls. It's working out well. I may ruin my sander ( I hope not) but it is doing the job and is cheaper than renting the BIG Kahoona sander from the BIG Orange box. I plan on priming the walls that were spackled before applying my wall paint.
Anything worth doing is worth doing right. My 2 cents worth.
Good luck with your nightmare. I feel your pain.
Sincerely,
Ray
