A55 Smoothing Plane
12v wiring
12v wiring
12v wiring
Allen Bryant - Bumpass, VA
>Interesting wiring question I have. I am working on an enclosed 20' utility trailer and have several 12v lights across the top. I want to be able to wire these up with switches at the front and back doors. I've looked around some but haven't found any 3 way 12v switches. Will regular household switches work? anybody ever done this before?
Re: 12v wiring
Re: 12v wiring *LINK*
>A 3-way switch is nothing but a single-pole, double-throw switch (SPDT). You can use any switch as long as the current/voltage ratings exceed that of your application, so house wiring switches (rated at 120v/15A?) will work fine. You can also go to Radio Shack or an electrical/electronics supplier or an automotive parts store and buy smaller SPDT toggle switches.
You can also wire up standard DPDT switches if you want "4-way".
The link below shows how 3 and 4-way lighting switches work.
how 3-way switches work
Re: 12v wiring
Re: I disagree...I think.
Al Stokka - Cambridge, Iowa
>John,
I don't claim to know how 3-way switches work (other than by magic) but, I DO know that both 3-way household switches on a lighting circuit DO NOT have to be in the same position, either both up or both down, for the lamp to light, contrary to what is shown in the illustration on the web page in your link.
Al
Re: 12v wiring
Bill Howatt
>If you consider the both up or both down applying to the diagram posted then it is correct. It would also be correct if the switches were wired that way but the traveller wires (the ones between the switch poles)can be crossed with no ill-effects other than the switch handles are now out of phase.
Bill
Re: 12v wiring
John McGaw
>I'm not sure what you are aiming at but if you are not driven by an overwhelming desire for a homelike appearance that regular household wall switches would give you, all you want to look for in switches is a SPDT (Single Pole Double Throw) toggle switch of the correct current rating. One with an on/on configuration, without the center-off position, would be desirable.
I don't know where you would look for such a switch in your area but locally I would expect to find them at my local electronic wholesaler or a marine/auto supply store. I've shown a link to a switch that would probably serve you nicely.
SPDT Switch at Grainger
Re: 12v wiring
>Al,
The diagram is correct. The "up" and "down" are arbitrary, depending on how you connect the wires and orient each switch. The key is they both have to be in one configuration or the opposite configuration to pass power. In either configuration, moving either switch but not the other breaks the power.
The 4-way switch wiring is even more interesting. When we moved to this house, one of three switches to a single light fixture had been wired incorrectly from the day the houses was built. It was interesting figuring out how it was wired and how to fix it. To get it straight I had to check the voltages with a meter and make a chart for all eight switch combinations.
The diagram attached is how to wire up a 3-way circuit from standard SPDT toggle switches as well as how to make a 4-way switch from a standard DPDT toggle switch.
Re: 12v wiring
Re: Yep
Larry Clinton At Frankfort (Central)., Indiana
>Alan, the only two things you have to be concerned with buying or using switches is the Voltage (must be rated as high or higher than the voltage you are using IE: for 12V you must have a MINIMUM of 12V - that is the rating of the insulation and air gap clearances so the switch doesn't short out. The other rating is the amperage rating - This is usually rated as XXX amps at XXX volts AC or DC - Now the only concern you may have is that the 12V application you have is DC - and DC is harder on a switch than AC as it will sustain an Arc longer and thus melts off a little metal from the contacts when you open the circuit. However the normal household switch has pretty good contacts and should last many cycles in your application - most are rated at 15A AC I would make an educated guess that they would have a normal life carrying about 5 to 8 amp at 12V DC. Most 12V lights are around 10 to 15 watt - this is about 1 amp. As long as you don't install too many in a string (more than 6 or 8 running off of one switch you should get good service from your switch. At the cost of around $1.00 a switch, you can always replace them in a few years if they do wear out, if they fail they will just quit turning the light on.
Note: I was the production Engineer over the Automotive switch lines for about 20 years before retiring - our company was the biggest supplier of GM brake switches for several years, also made Headlight, maplight, Winshield wiper, Hazard, and many other switches.
Re: 12v wiring
Re: Still not getting it
>John,
It seems there either are be conductors missing in your diagram or ? I'm referring to the upper circuit. If one switch were up and the other down, the light won't go on. Both switches must be in the same position, either both up or both down, in order to power the light. This is contrary to the operation of two 3-way houshold switches. Is there, perhaps, circuitry internal to the switch that isn't shown in the diagram>
I'm not trying to be argumentative. Just trying to understand.
Al
Re: 12v wiring
Try it on a 3-way in your house
Henry Higginbotham
>On one in a hallway in my house, the switches have to be in OPPOSITE directions for the light to be on. But if I simply unscrewed one of the switches and turned it 180�, without rewiring anything, then the two switches would have to be the same for the light to be switched on. Orientation is arbitrary.
