100 amp to 200 amp
100 amp to 200 amp
100 amp to 200 amp
Mitch from Canada
>Hey guys (and ladies),
I brought up the idea of running more power to my garage in another thread last week. After chatting with a friend of mine I'm 98% sure I have a 100 amp panel in my house. Can I have it changed to a 200 amp panel using the existing main lines coming in to feed the 100 amp panel?
Thanks.
Mitch
Re: 100 amp to 200 amp
Chuck in ND
>Your information is pretty limited. It depends on what the line is thats comeing into your shop. It's best if you talk to a local electrician that knows the code in your area. Maybe even have him do it for you, then you have the peace of mind that it's done right. In here you will just get 100 different confuseing answers.
One person's experience…
Rod Peterson -- Ormond Beach
>I did exactly that 30 some years ago in our first house in Illinois. In my case I planned to use the box housing the existing fuse panel as a large junction box and I installed a new 200A load center in the adjacent stud bay. I then connected a meter socket on the outside of the garage, the vertical service feed conduit, the weather head, and the 3/0 conductors in preparation for ComEd to string the new service from the pole. Imagine my surprise when instead, they just cut the existing line over from the old weather head to the new one.
It seems that they have a lot more flexibility rating wires in free air than we do in conduit or raceways. Of course it could be that oversized wire was strung in the first place when the house had been built 15 years earlier, but that doesn't sound like a developer's practice, does it?
In any event, that was 1974, it was Illinois, it was a particular community in Illinois, so there are a lot of things that may be different there and now. Also, I see you're in Canada—they may not be so considerate of DIYers when it comes to being permitted to roll your own. By all means check and find out. While some may be tempted to undertake in-house wiring without permits, ComEd, and I'm sure most any utility won't begin to cut it over without the imprimatur of the AHJ (authority having jurisdiction). Obviously, I jumped through all the hoops.
Rod
>Check your panel. Your service disconnect breakers at the top often say what amperage you have - and your panel should say what it is (100 amp or 200 amp). If your house is of recent vintage, it should be 200 amp.
At any rate, if you have to do a panel upgrade, have a local electrician do it.
Dale Lenz
Re: Listen to Chuck below...
Dale Lenz
>Your incoming service wire size is the limiting factor. I suggest you read and heed Chuck's information.
Dale Lenz
Re: Listen to Chuck , EDIT: ahhh above
Dale Lenz
Bill Howatt
>You may be able to get an answer from your local electricity supplier. This is one job you have to get a permit to do unless you really like living on the edge since you have to kill the power to the house.
I had a house that had 200A underground to the meter-base but a 100A service. This was put-in when the house was being built and the big push was on for everybody to live better electrically. It was necessary to change the wire from the meter base into the new panel to the 200A size and this also caused a change in the size of the ground wire. Also, the ground wire had to be run right back to the street side of the water shutoff valve instead of just being clamped onto a pipe near the panel. I have no idea what the regulations are now regarding all of this.
I did it myself with the aid of person who used to help a local electrician but this isn't a job if you are just learning wiring. They will not reconnect your house until it passes inspection.
Bill
Larry Clinton At Frankfort (Central)., Indiana
>Mitch, I don't know what the codes or requirements are in Canada. I am sure most on this forum will not have sufficient information to give good advice. However first, I would open the door to your breaker box, and read the numbers on your main (biggest breaker above all the others) breaker - It will have the amp rating on the handle - 100 would mean you have a 100 amp service etc. Now, since you are not sure what your current box is rated at, IMHO you have no business installing an entrance in your home. Not trying to be a smart aXX, but anyone with the knowledge to install a service would have NO question what your current service is rated at. As for some general information, (having installed many services over 40 years as a side job) 99.99+% of services I have seen or installed DO NOT have the proper wire size or even conduit size required to upgrade from a 100 to 200 amp service. If the installer spent the money to install the proper wire and conduit for a 200 amp service, he would install the 200 amp service panel. The difference in a 100 and 200 amp service panel is a whole lot less than the wire and conduit cost differential. As requirements vary even by counties in the state of Indiana, and many states vary, I would not even attempt to guess what is the proper size ground rod, ground wire, Meter base, conduit size (often dictated by both the wire size and the length of the drop wire from the utility pole) or cable size required for your entrance in your locality in Canada. IMHO, if you don't have a 200A service and want to upgrade, you need to contact a few electricians & obtain quotes, talk to your local building code office then figure out how to proceed.
Re: Call your power company
Brian in Brighton
>They should be able to tell you what you can do.
Brian in Brighton
