Cutting steel with band saw ??
Wayne Carson "TX"
>I would like to cut some annealed steel 1/8" with my band saw. What do I need to know, blade size # of teeth?
Re: Cutting steel with band saw ??
Lee Schierer - McKean, PA
>A wood bandsaw is not a suitable tool for steel cutting. The blade speed is much too high. You will also need a metal cutting blade.
Lee
kind of what I thought O well jigsaw
Wayne Carson "TX"
Al Stokka - Cambridge, Iowa
>Even though Lee told you a wood-cutting band saw is not appropriate for cutting steel, Here's some information for the future:
1/8" thick mild steel should be cut with a 24 TPI metal-cutting bandsaw blade. The speed should be between 150 and 200 FPM. Wood-cutting band saw usually run about 3000 FPM.
Al
>I don't know how refined your cut needs to be but I do some cutting with my Sawzall. I use Milwaukee's blade called "The Torch".
Tom
>I agree with all those who said you can't do this on a wood cutting bandsaw.
And, there is another reason. I cut some aluminum and copper on mine, using the same blades I used for wood. The cuts were rough, but OK for what I was doing. But then I opened the doors on the saw. Those darn little splinters and slivers were every where. It was ugly, really ugly. They will stick in your skin fifty times worse than wood. And, they stuck in the rubber of the wheels. Not a good thing to do.
Even with another type of saw, wear Eye protection.
>I use either a portaband metal-cutting bandsaw or a metal-cutting blade called "The Torch" in a reciprocating saw. It's amazing how well the recip saw works. You can buy the blades at HD - check the package for the right pitch for the thickness you need to cut. Both of these methods are preferred over abrasive cutting.
As other's have said, don't try it on a bandsaw made for wood only.
It can work
Bill Tindall, E.TN
>1. you will need a fine tooth metal cutting blade
2. By some means you will need to slow the blade speed. For my 14" machine I needed to slow it by 20 fold. I accomplished this task by running a belt from the saw to a pulley mounted between centers on my lathe, which I can make turn very slowly.
Crude, yes. But I had much to saw and it worked.
Denis Ch�nard, Orl�ans, Ont.
>There was a piece in AWW a few years ago where they used a standard bandsaw to cut metal. Basically they were using friction from the blade to "melt" the metal away, not unlike using an acetylene torch. I don't remember the type of blade used, I suspect bimetal.
Personally I wouldn't use that method, as I'm pretty sure it can't be good for the tires and the rest of the saw. Then there's the fire risk if your saw isn't cleaned up first. Don't even think about dust collection...
DC
