Resharpening brad point drills?
wilbur
>I was doing something stupid with a brad point drill this weekend (don't ask) and managed to break off the cutting spurs. Is there a way to reshape the tip to restore the cutting spurs? All I know is that a Drill Doctor won't work for this application.
Re: Resharpening brad point drills?
Krenov describes the porcess
Bill Tindall, E.TN
>If you have a grinder with a wheel that can hold a sharp edge then you can regrind a successful brad point. I make them from time to time from ordinary metal twist drills. I think the process is briefly described in one of the Krenov books.
Look at the brand point drill and see what metal has to be removed to reestablish the cutting edges. By orienting the edge of the wheel between the outer edge of the bit and the center you can remove a grove which will leave a lip and the center spur. The metal removed has a flat bottom on some brad points. Unless you have a narrow wheel you won't be able to make the bottom flat using the edge of the wheel. It will be vee shaped and as far as I can tell still works fine.
The outer lip is easy to establish. The trick is to keep the point and keep it centered.
