How to re-flatten a panel
Bart Goldberg
>I'm in the process of making a desk for a friend's birthday. I made the top first - 56 inches wide x 38 inches deep all from flat sawn white oak. After sanding the top smooth, I had put it aside while I started on the carcass construction.
Now that I've completed the carcass - I went to check on the top and found that it has cupped from the center and is slightly "c" shaped.
I tried just laying on the floor with some scrap ply piled on top to re-flatten it- but it hasn't moved much after about a week. So, I'm thinking that I would try some clamping type method - I created some three sided boxes/clamping cauls - that I would use to clamp the panel too, and start using clamps to try and flatten it -
Any opinions?
Bart
