REAL MILK PAINT
OT Notebook Computer questions?
>My son gave me his "old" laptop. Its and Acer with Centrino Duo processors running Vista something or other. I have no experience with a laptop or vista.
The computer fails to react to the "touch pad". I have hooked up a track ball I had with a USB slug on it and that went to work.
There was some sort of warning about "new hardware" and wanting to install drivers and I told it to go ahead, but that failed. That was before I found the track ball and I thought it might be the machine's effort to reconnect the touch pad. But maybe not.
So, any advice on how to get the touch pad working? Any other advice?
Re: OT Notebook Computer questions?
Chuck W
>Laptops are notoriously fragile and short lived. In fact most manufacturers don't expect their products to last much longer than 2 years. That said you likely need the driver disk for the trackball you have plugged in.
>>...There was some sort of warning about "new hardware" and wanting to install drivers
A suggestion: the next time you get "some sort of warning" take a moment and write down the exact text, what you did, and any further messages. That can go a long way towards figuring out a solution.
Steve in Denver
>Check under the Control Panel / Settings. There should be a "Mouse" option. I have a Tab called UltraNav and there's an option to enable touch pad. Make sure yours is enabled.
Hamish
>I think you should ask your son about it, as I'm sure he has set it up the way he liked it, at least he will know where to look.
>I tried that. His response was something like, Huh, it doesn't work? Hmm! Don't know what to tell you.
He's in the army and on his way to Afghanistan and out of touch for a while.
Jerry Nicholson
>I don't know anything about Acer computers but I really don't like touchpads and use a wireless USB mouse on my laptop. I don't even know if the touchpad works or not! BTW I have a 9 year old Toshiba laptop that stills works just fine within the limits of 1999 technology. I dropped it about three feet to an oak floor once but it landed flat and didn't seem to suffer any damage. I am not sure later model Toshibas are that tough.
Jerry
Re: OT Question on mouse?
>This question might be self evident if I owned such a mouse, but is there some part that has to be installed in the computer to make it work?
>Many mice will plug right into a USB port on many computers with Win2K or later operating systems. Even if tells requests a driver disk (which comes with the mouse) you can often ignore it and the mouse will work fine. I've done this twice in the last year.
A wireless mouse, BTW, has a little part that plugs into the USB port and communicates with the battery-powered mouse. You can get these at Walmart, office supply stores, and probably in a kiddie meal at McDonalds.
Pete Stahl
>Go to the Acer web site and download the driver for the touchpad for your Laptop. Also like someone else said try and find out what the error message says to see if it is the touchpad. I don't like the touchpads and use a little USB Laser Mouse. I use a wireless keyboard mouse combo for my desktop PC and get a error message every time it boots up saying it can't find my keyboard. Maybe your touchpad drive got corrupt or is missing?
