its the wheel and tool rest that is important
Bill Tindall, E.TN
>For tool griding any grinder will work, even a home made one from a Lee Valley arbor and a used motor. Any of them will need a better tool rest- Wolverine or home made. I think the Veritas is too flimsy. With the right wheel one can grind right to the edge of tools with out burning the edge, even with a 3600 rpm speed. A crowned 7" x 1/2" wheel is ideal. The hollow is just right for the following steps, see below. 7" wheels are readily available cheap from machine shop supply places as they are the common wheel for surface grinders. See Articles for a discussion of the right wheel.
After the grinder, only a few strokes (5-10) on a fine fixed diamond plate are necessary to straighten the edge if it isn't perfect off the grinder. These few strokes can be easily done free hand by skewing the tool some to get more support on the abrasive surface and then pulling the tool toward you. You will feel the tool suck into the surface and orient perfectly. Try it with a hollow ground tool and see how easy it is. After the fine diamond stone, hone with something finer- water stone, sheet abrasive, loose diamond on cast iron, etc. I use 1 micron diamond on cast iron. With the hollow grind it takes only a few strokes on the abrasive to complete the sharpening.
At a recent show our club did a sharpening demo. A neighboring booth had a chair maker with a dull plane iron. We ground a new bevel and honed the edge as described above in abut 2 minutes.
There have been many discussions of this technique over on the hand tools side by me and others. Search "diamond".
