200+ woodworking book reviews
Mortising machine question
Joe in a Cleveland suburb
>I just bought the Steel City model. The bit does not go all the way down to the base. Should it? It stops a little short.
Thanks.
Joe
Re: Mortising machine question
Re: My General does the same
Peter Gregory
>I assume that driving the bit into the metal table isn't a good idea? :) Put a piece of something under it, that is flat and you are good to go.
North of the Border
>Nothing wrong with your machine - the chisel is not supposed to go all the way down or it may hit the metal base by accident. Put a filler board at the bottom of your work piece where necessary for the chisel to reach the depth desired.
